04-09-2020, 10:07 PM | #1 |
OEM+ -S15 Spec R braces in S14
I began acquiring all the oem jap Spec-R braces about a year into owning my s14. Being new and wide-eyed to the s-chassis platform I was bold and stupid. I was fascinated about having them and using them rather than getting a cage.
This thread is to display what doesn't work and what does, without too much headache. So we have these that came from factory on the top tiered Spec-R s15's I'm sure they came on a few other models, I'm just not 100% sure: - Keep in mind. All these braces are a bolt-on affair for the S15 chassis. Spec-R - Front ladder brace Spec-R - Rear subframe brace Spec-R - Roof Brace Spec-R - Trunk Brace Spec-R - Trunk Triangles Spec-R - B-Pillar braces Spec-R - A-Pillar plate braces Spec-R - C-Pillar plate braces Spec-R - Front Strut Braces Plates Spec-R - Rear Strut Brace Plates -------------------------------------------------------------------------------- Spec-R - Rear Subframe brace Here's how it fits on a Spec R - https://ibb.co/rc2QqMg Here's how it can fit on an s14. - https://ibb.co/xqQCB8r How can we make it fit in an s14? Very easy bolt-in affair. Just don't use the s14 subframe bolt plates the brace replaces those plates. -------------------------------------------------------------------------------- Spec-R - Roof brace Here's how it fits on a Spec R - https://ibb.co/CQgjjRY Here's how it can fit on an s14. - https://ibb.co/7XFmMLz - https://ibb.co/KWdzZs5 How can we make it fit in an s14? Don't - Use the factory bolts with the Moonface roofbrace. Otherwise you'll cut into your good metal roof and cut into a rare-ish piece. S14 roof factory bolts holes - https://ibb.co/0Bxtqv4 https://ibb.co/phrVPMy Moonface roof brace - https://ibb.co/0nPJpdY https://ibb.co/YDfhD7w -------------------------------------------------------------------------------- Spec-R - Front ladder brace Here's how it fits on a Spec R - https://ibb.co/7YB0qHB - https://ibb.co/R0Gj5Rb Here's how it can fit on an s14. How can we make it fit in an s14? -------------------------------------------------------------------------------- Spec-R - Trunk brace Here's how it fits on a Spec R - https://ibb.co/23RTMC4 Here's how it can fit on an s14. - https://ibb.co/3p6XLBk How can we make it fit in an s14? An easy bolt-in affair with our own Zilvian Bernie(Nova) making spacers in conjunction with hardware for the brace. -------------------------------------------------------------------------------- Spec-R - Trunk Triangles Here's how it fits on a Spec R - https://ibb.co/DGR1fHF Here's how it can fit on an s14. - https://ibb.co/C1H3CHb - https://ibb.co/tzZhzF3 How can we make it fit in an s14? With a drill, couple bolts, washers, and a hammer. Just make sure you drop your gas tank first before drilling otherwise you'll have a whole other headache. Also make sure the bolts aren't too long to rub against the gas tank when re-installed. Some light massaging of the trunk sheet metal will be required to flatten it for a flush bolting surface. -------------------------------------------------------------------------------- Spec-R - B-Pillar brace Here's how it fits on a Spec R - https://ibb.co/10VMSmZ Here's how it can fit on an s14.- https://ibb.co/pvGvd30 https://ibb.co/D54pjwv https://ibb.co/tcFQBMq https://ibb.co/s2jPWnY How can we make it fit in an s14? Don't - unless you are planning to have no rear seats. If the rear seats aren't used and the car is going to be a designated track car of some sort you can cut the plates and body to fit. But, these are not a bolt-in affair and will be in the way of the interior panels and seat bolt mounts if you plan on running those oem s14 pieces. -------------------------------------------------------------------------------- Spec-R - A-Pillar Plate Brace Here's how it fits on a Spec R - Not Pictured Here's how it can fit on an s14. How can we make it fit in an s14? -------------------------------------------------------------------------------- Spec-R - C-Pillar Plate Brace Here's how it fits on a Spec R - https://ibb.co/WfJZxH2 Here's how it can fit on an s14. - No picture How can we make it fit in an s14? - There's no way this will fit due to the body being a different shape. -------------------------------------------------------------------------------- Spec-R - Front Strut Plate Brace Here's how it fits on a Spec R - https://ibb.co/XzxCfvC Here's how it can fit on an s14. - Sits on the top of the top hat when installed from under in the wheel well. How can we make it fit in an s14? Easy drop on plate to the coilovers or strut. -------------------------------------------------------------------------------- Spec-R - Rear Strut Plate Brace Here's how it fits on a Spec R - https://ibb.co/yhpz2ST Here's how it can fit on an s14. - I truly don't see these fitting at all. How they are shaped it would need cutting How can we make it fit in an s14? Don't, get a rear strut bar of some sort which would do the same thing while aiding in rear rigidity. -------------------------------------------------------------------------------- I'll be updating this overtime with more pictures of the pieces as I start mocking them up on the s14. Last edited by Fitelite240!!; 04-10-2020 at 08:08 AM.. |
02-04-2021, 11:37 AM | #2 |
Good info here, wish I could find more pictures of the b-pillar braces in an S15. Like how is the seat belts mounted in that chassis? Wanted to try to attempt to get those installed in my S14.
The front ladder brace would be a good find. The frame rails look similar, wonder if it's as simple as popping in some rivnuts and bolting that thing up. |
02-04-2021, 02:14 PM | #3 | |
For the B-pillars eh, Im thinking of just making my own. same thing with the C-pillars |
03-08-2021, 03:45 PM | #4 | |
03-08-2021, 04:33 PM | #6 |
just pm your phone number hassale to load pics up from phone or you can check out my ig mrnismos14
03-08-2021, 04:47 PM | #8 |
03-08-2021, 05:26 PM | #10 |
09-18-2022, 03:50 PM | #11 |
I got the front ladder brace installed in my s14 today.
Had to ditch a heat shield by the downpipe. Installed M10 rivnuts to the rails to hold everything in place. I put a washer between the brace and the body on the left, front most bolt. This is because the S15 has some extra stamping fit this bolt (can be seen in the S15 pics in the first post). For the holes, I found a step bit to be the easiest way. Don't forget to paint the drilled areas to minimize rust in the future. Gallery of pics: https://imgur.com/a/4vEMSYX |
01-21-2023, 10:43 PM | #12 | |
01-22-2023, 11:20 AM | #13 |
This an interesting thread…
I’ve considered fabricating an entire chassis brace that is bolted to the underside in various locations, similar to the UR braces. The main reason I’ve considered it is so that I can put a belly pan on the entire underside of the car.
01-22-2023, 01:07 PM | #14 | |
Feel like it's a missed potential for the aftermarket to duplicate this part. |
01-22-2023, 01:49 PM | #15 | |
https://ultraracing-usa.com/product/...s14-1995-1998/
01-22-2023, 03:34 PM | #16 | |
01-22-2023, 04:12 PM | #17 | |
If used turns up nothing, you might still be able to buy the brackets new. Looking on Nengun, here's part numbers. They don't say discontinued, but someone would have to place an order to find out... Front Crossbar Assembly - 544B2-85F00 Rear Crossbar (subframe brace) - 554B2-85F03 (or 554B2-91F00) Trunk Triangle brackets: Rear Floor Stay Lh - 74845-85F00 Rear Floor Stay Rh - 74844-85F00 Trunk Bar Assembly - 79174-85F00 B-pillar brackets: Floor Gasset Rh - 748B0-85F00 Floor Gasset Lh - 748B1-85F00 |
01-22-2023, 04:54 PM | #18 | |
03-02-2023, 05:33 AM | #19 |
Update If anyone is still interested. I have now installed the rear subframe brace and the front ladder brace, both at different times. I started with the rear subframe brace and noticed an immediate difference with greater turn in response. I then installed the front ladder brace and notice further improvement to rigidity and turn in response. All in all both are highly noticeable and I wish I installed them sooner on in my ownership.
01-13-2024, 03:36 PM | #20 |
Just picked the spec r boot brace and triangles. Would Riv nuts be fine to fix it to the boot floor or is there a plate/thicker floor in the boot of the s15 to allow for the point fixing of the boot brace and triangles?
01-14-2024, 09:47 AM | #21 | |
just to confirm, these 2 braces were 100% bolt in using factory munting areas and hardware? which braces do have you installed and which ones made the most noticable difference, (besides these 2) ? |
01-14-2024, 04:44 PM | #22 |
I picked up the factory panels that are spot welded to the floor and will use rivnuts on the back wall. I've seen others get away with just rivnuts. It'll be my winter project at some point. Only issue is the tank is right there, so need to be careful with the drill or drop the tank.
01-14-2024, 04:47 PM | #23 |
The front ladder brace needs rivnuts installed in order to mount. The subframe just replaces the cup washers and goes right on with no mods. The ladder brace was immediately noticeable, and was a big surprise to me.
