Old 03-29-2022, 03:30 PM   #1
ragamuffin
ragamuffin will become famous soon enoughragamuffin will become famous soon enoughragamuffin will become famous soon enoughragamuffin will become famous soon enough
JDM Wing question - broken studs
Hey everyone,
I tried searching but didn't find anything on this topic. I bought a used JDM kouki wing for my s14 and the stud on one side of the wing (marked in red) is smaller (likely cut off). It needs to be longer so that I can secure it to the car.
Any advice on how I could fix this? I'm adding images for context. Appreciate the help!
Here are the pics: https://imgur.com/a/5tHM8Qp
Last edited by ragamuffin; 03-29-2022 at 03:31 PM.. Reason: updating car model info
ragamuffin is offline   Reply With Quote
Old 03-29-2022, 03:44 PM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Chop it down and have someone weld a new one to the stub of the old one.
Or press the old one out and install a nut-sert, and then use a bolt from underneath to attach.
Old 03-29-2022, 04:16 PM   #3
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Send a message via AIM to s13 @ fullboost
Nut cert is a solid repair like brndck said. I think that would be the best approach IMO.
s13 @ fullboost is offline   Reply With Quote
Old 03-29-2022, 05:22 PM   #4
inferno s14
inferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-knowninferno s14 is making his/her stupidity well-known
let me know if you want to sell that wing
inferno s14 is offline   Reply With Quote
Old 03-29-2022, 06:26 PM   #5
ragamuffin
I think it'd make sense to weld an extension of the stud. My concern with the nutcert is that the it wouldn't be embedded anywhere. If you put in a wall, it's held in place on all sides, but in a wing, there's just a layer of plastic that the nutcert is piercing, and that's the only thing holding it in place. Hope I'm making sense since I don't know anything about working on cars, but I'm trying to learn here.
If I decide to sell, I'll let you know. I waited years to find one local to me.
Old 03-30-2022, 07:48 PM   #6
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
The way I mounted my Kouki wing in the past was with 3m double-sided tape + stud/nut. It will be similar if you did the nut-sert like brndck said.
instagram
1on1 is offline   Reply With Quote
Old 03-30-2022, 08:56 PM   #7
burnsauto
burnsauto's Avatar
If you're worried about the nut-sert not holding onto the plastic that well, you could always remove that broken stud, and then drill an access hole near where the stud was. you could feed another bolt through, and with a little patience, get it sticking out of the original hole where the stud was. You can use a pushnut washer to hold the new stud in place. Once done you can then plug up the access hole with a rubber plug if you'd like.
jdm, kouki, s14, spoiler, wing
