Old 04-27-2022, 11:01 AM   #1
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Arrow Garage Sale - S13 & S14 Massive Parts List - Interior / Exterior/ Trim / Brakes +more
SHIPPING: At buyers expense
CONTACT INFORMATION - [email protected] or via PM.
PAYMENT OPTIONS: Cash, Paypal
Updating this throughout the day and adding more parts as they become available.
S13
$60 - S13 LCA Set (good ball joints and bushings)
$10 - S13 Triple gauge holder
$10 - S13 Dual gauge holder
$30 - S13 E-brake Cable set
$20 - Throttle pedal
$20 - Brown LH Kick Panel (no cover)
$30 - Brown Door sills
$20 - Fuel lid door
$15 - Rear interior light
$20 - Coupe trunk latch
$40 - Coupe rear bumper brackets
$40 - Hatch rear bumper brackets
$20 - Rear seat latch brackets
$50 - Hatch rear bumper support
$30 - Dome Light (S13 or S14)
$20 - Door Handle Pull (LH or RH available)
$20 - Door Handle trim (LH or RH)
S14
$100 - S14 Rear Calipers with pads (refurbished set)
$250 - '95 S14 Zenki Engine Harness
$50 - S14 Rear Bumper Support
$100 - '95 S14 Heater Core Box
$30 - S14 Speaker Door Bracket Set
$50 - S14 Zenki LH Taillight
$60 - S14 Cruise Control assembly
$30 - S14 Charcoal Canister
$50 - S14 Fuel Filler Neck
$100 - S14 Dual Diaphragm Brake Booster
$200 - S14 Front Knuckles with ABS sensors
$60 - S14 Rear Lower support bar
$15 - Steering wheel spacer
$10 - black spin knob
$50 - S14 Blue Subframe Collars
$100 - S14 Rear Seat Plastic Panel Set
$75 - S14 B/C Pillar Set
$25 - S14 Kouki RH Door Handle
$15 - S14 RH Triangle mirror cover
$20 - S14 Driveshaft tunnel brace
$15 - S14 Rear Bumper Brackets
$25 - S14 Rear Factory Tow Hook
$250 - S14 Zenki LH Fender (Mint)
$40 - S14 Zenki RH Fender (Damaged)
$250 - S14 Zenki OEM Bumper Support with retainer
$75 - S14 Rear Seat Belt Set
$25 - S14 Zenki Hood Prop
$20 - S14 Rear Seat Belt Buckle (two available)
$20 - S14 Lower Dash / Steering Column bracket (three available)
$10 - S14 Fuel Filler Neck Hose
$75 - S14 Rear Bumper Brackets with hardware
$30 - S14 Power Steering Cooling Hard lines
$75 - S14 RH Glass Window
$10 - S14 RH Door Speaker Bracket
$50 - S14 Wiper Linkage Arm Set
$100 - S14 EVAP Box Assembly ('97 Kouki)
$20 - S14 Windshield Wiper Cowl Metal Cover
$30 - S14 Fuel lid door
$20 - S14 Glove box bracket
$50 - S14 Rear Seat Trim
$10 - S14 LH or RH Weatherstripping Retainer
$30 - S14 Fuel Pump Sender Cover
$40 - S14 ABS Pump Assembly (95 Zenki)
$30 - S14 PS Reservoir
$50 - S14 Dash Bar
$30 - S14 Rear Exhaust Heat Shield (bolts on above muffler)
$25 - S14 Center Exhaust Heat Shield (bolts on above catalytic converter)
Misc
$100 - Ford Taurus Electric Fan assembly
$60 - MSD Blaster Ignition Coil
S13
$20 - Fuel lid door
S14
$50 - S14 Rear Bumper Support (newer replacement)
$100 - S14 Kouki Center Console
$15 - S14 LH Triangle mirror cover
-Jspec-
Instagram/CrimsonRockett
