![]() Join Date: Jan 2011
![]() Feedback Score: 10 reviews
![]() Im thinking about gettng a cusco diff from someone for a pretty good price, however its for an s13...
what would i need to do to use this diff in my s14? |
![]() Join Date: Jan 2004
yup just replace the diff cover. i'm not sure if it matters, but i also switched the bolts to the subframe as well when i swapped diffs between my s14 and s13.
D-Street.net | bcuison.wordpress.com |
![]() Join Date: May 2008
If you still have the s13 differential, there is no "bushings" to mount the diff to the chassis, the s13 differentials are just solid mounted w/ bolts.
If you have an s14 or z32 or j30 pumpkin, then yes, you can use those bushings. In fact you can even go solid bushing: S14 240sx Solid Differential Bushings. ![]() The s14 subframe has these nice gay bushings to let your diff jump all over the place.. While the S13's subframe doesnt have any stupid bushings where the diff mounts.. ![]() So if you use an S14 diff on an S13 subframe, the front mounting points may line up, and bolt up, but then ANY torque applied is going to be absorbed by the aluminum diff cover which is rigidly mounted to the subframe, not the bushings installed in the front mounting points, as designed. doing it the other way has no "ill effects" because the cast iron diff is going to absorb all of the torque, while the rear mounting points on the aluminum diff cover are mounted in the S14 subframes bushings. Hope this helps..
i have done the swap from an s14 to an s13. all you need to do is swap the rear diff cover to the chassis that you are using it for... use rtv to seal it up that will work fine.
take your s13 diff and put your s14 cover on it. mount it back in the car using the s14 bolts... and you are good to go. ![]() |
#10 | |
Man w/ CTSV & a Car Seat
S13: ![]() ![]() S14: ![]() ![]() |
As others have stated previously, S13 differential assembly (case, actual differential, output shafts Also known as pumpkin) to be installed into an S14 subframe should just require you to swap a rear cover from an s14.
I have previously verified this but it's been years since I did ( I have a problem with hoarding parts, so don't ask me to dig anything out from my basement that might one day be on Hoarders? the TV series) I can't tell if you have been hacked an are commenting the same shit on different posts or if you are like me on facebook and comment or like something so you can find it later. |
![]() Join Date: Jun 2003
Trader Rating: (130)
plz don't bump graveyard threads unless you have new or relevant info to contribute.
accurate post is accurate. |
#14 |
At the top of each page, there's a Thread Tools button. You can subscribe to threads that way if you want to find them later, without having to bump ancient threads
Other than his build thread, all of that guy's comments the last few years are generic "thank you" bumps. Kind of odd, but at least he doesn't seem to be a spam bot, lol. |
