Old 07-29-2022, 05:35 PM   #1
RepS13.Abe
RepS13.Abe is an unknown quantity at this point
SR20 starts up but doesn?t idle, seeking insight
Seeking some assistance here, I recently did an SR20DET swap into my 90 s13 hatch, I got it to start up but doesn?t run or idle, it just kinda sounds like it chokes itself out, I tried holding open throttle while It cranks but nothing seems to happen just falls flat on its face, I currently have an AEM340 pump, radium fuel rail, 850cc top feed injectors, Apexi power ECU with commander, MAP sensor, wiring specialties harness and Greddy FMIC, any insight on why it?s not wanting to idle
RepS13.Abe is offline   Reply With Quote
Old 07-29-2022, 07:31 PM   #2
Kingtal0n
Kingtal0n's Avatar
did you tune the engine using a wideband to run at correct a/f ratio
Old 07-30-2022, 03:29 AM   #3
RepS13.Abe
So I haven?t hooked up my wideband O2 sensor yet, seems the wiring specialties plug is different from the AEM that I have, would that be an issue or can I run the AEM just on itself and not through the harness
Old 07-30-2022, 05:26 PM   #4
Kingtal0n
Kingtal0n's Avatar
wideband is a gauge. You read wideband instructions to install gauge correctly. Then, you tune the engine while you watch the wideband behavior.
Old 08-01-2022, 12:19 PM   #5
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Feedback Score: 18 reviews
Sounds like you really just need to get a base-map installed in the ECU that accounts for injector size, etc. Verify it has a good startup tune first, then start chasing down other things like vacuum leaks or wiring/sensor issues.
LoSt180 is offline   Reply With Quote
Old 08-01-2022, 02:10 PM   #6
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
have you verified FAST???
Fuel
Air
Spark
Timing.
start there, then report back
*also make sure your fuel lines are not switched*
Old 08-03-2022, 12:08 PM   #7
jedi03
common issue is hooking your fuel lines up backwards eg feed goes into the FPR first vs through the rail first
Old 08-03-2022, 09:24 PM   #8
RepS13.Abe
Yea so that?s another thing I was also thinking I overlooked, since it starts up for like a few seconds and just dies, but when I open the throttle it tends to have no input like it just chokes out
Old 08-03-2022, 09:25 PM   #9
RepS13.Abe
I currently have not tuned it since I can?t get it to idle or run
Old 08-04-2022, 04:14 AM   #10
lok
lok's Avatar
lok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond reputelok has a reputation beyond repute
You have
850cc injectors
MAP sensor
Power FC with no tune
Doubt it will start and idle
lok is offline   Reply With Quote
Old 08-04-2022, 06:11 AM   #11
LoSt180
LoSt180's Avatar
Trader Rating: (18)
You need a base tune to get it to start. You're probably flooding the engine since the ecu is most likely set up for smaller injectors.
Old 08-04-2022, 07:58 AM   #12
tuzzio
tuzzio's Avatar
Correct me if im wrong but...isn't a power FC for MAF vehicles? Because thats probably a big issue
Old 08-04-2022, 11:22 AM   #13
brndck
brndck's Avatar
yes, but there is also a "d-jetro" version of power fc that switches to MAP sensor.
Old 08-04-2022, 01:48 PM   #14
RepS13.Abe
Ahh I see so my best bet is to get a base tune then, I?m going to connect everything else and go about getting a tune then, thanks all for the input I?ll come back with an update lol
Old 08-05-2022, 03:26 PM   #15
brndck
brndck's Avatar
this is why we're known for being a$$holes and always saying SEARCH NOOB
https://zilvia.net/f/showthread.php?t=226628
