S14 rear calipers vs Z32 rear calipers for drag wheels
Hi,
I was wondering if anyone knows how much larger the Z32 rear calipers are compared to the stock s14 rear calipers. I know Weld has wheels that will fit the S14 but not sure if they will clear the Z32 calipers. Anyone know or have some helpful info? Thank you, |
![]() Join Date: Sep 2004
hate to be the bearer of bad news, but they're much larger. nothing astronomical but if you're trying to figure out things for stuff you haven't purchased yet or not even in your line of sight financially. best not to fantasize about them fitting or not until you have them in your possession.
Dickhead answer, sure. But this could've been asked in the small questions thread. |
![]() Join Date: Jun 2003
Trader Rating: (130)
but what do 240's in women's clothes have to do with brake clearance???
I swapped to a full 5 lug setup and already did the z32 brakes in the rear. I?m trying to avoid going back but might have to. Not really fantasizing here but trying to see what works best with the least amount of work.
Also, if I’m looking at weld wheels for a drag setup, don’t think I’ll have an issue financially. |
#6 | |
I moved about a few months ago and not sure if I still have the old rears. Haven't been able to find them yet. Figured this might be easier because if I can't find them, I'll just buy a pair of s14 rears but keep everything else the same as it is now. Not sure if the bigger rotor with smaller caliper would be an issue but then I guess I can just buy a stock size rear rotor.
Trying to maintain better braking but might have to switch back to the old rear calipers for the Welds to fit. Then gotta figure out the front fitment after. |
#8 | |
Yea, I was looking at the weld RTS. Real street has them listed for the 240 and says they fit. My concern was clearing the z32 calipers but sounds like they worked for you? I know the 15?s can clear stock s14 brakes based on what they have listed.
Have you tried looking up Z32 fitment wheels to see if they match up? Stock S13 15" wheels will clear z32 calipers, so it's really comes down to spoke design on the wheels you're looking at.
I've tried fitment about the same weld wheel on a Z32 and have had no luck. I know real street has the welds and states it fits the S14. I've reached out and they have no idea if it'll fit a Z32. I know spoke design can be an impact but its almost a guessing game between spoke design and fitment.
I'm not trying to spend almost 800 on one wheel to chance fitment and then be stuck with it. That's why I was hoping someone might have an idea. Looks like I'll just buy the ones that fit the S14 and then swap our the rear calipers if needed. |
Thank you for posting the FB post. I don't use FB so I couldn't search on there. I am running Import Drag Solutions coilovers and they did mention running 6.5 but would require pulling fenders on a 9 wide. Seems like this might be pushing it. I was hoping to run a 15x8.
Wonder what the difference could be. |
#14 |
![]() Join Date: Oct 2013
If you run the same back spacing, you should have about 3/4" more clearance with a 8" vs a 9.5".
However, height and tire size all come in to play here. You're not afraid to drag the car, but youre afraid to pull fenders? |
#16 |
Why not get the 8?s and throw a spacer on? You?ll have to get different studs anyway to run the Welds?
#18 |
Weld spacers to wheels, no issues. I would agree with bolt on spacers, but slip on makes no sense. 3-5mm is probably all you’ll need.
#19 |
Sounds good and thank you.
Looks like I'll have a few options either way whether its spaces, possibly going wider or just putting the old calipers back on. Trial and error at this point. |
#20 |
Measure the difference between the current wheels/brakes and then throw an old unit on to see the difference.
#21 |
I can do that but I still don't know the spacing on the Weld wheels is compared to the stock calipers.
Someone already mentioned the z32's are bigger. All that would tell me is the actual size difference but still not know fitment. Plus, I still need to try and find the old calipers, if I have them. |
