Old 11-30-2022, 10:51 AM   #13
jdm60
jdm60's Avatar
jdm60 is on the path to ruinjdm60 is on the path to ruin
Originally Posted by dbeiler View Post
There is only one wire to the AC compressor. It is the power wire for the compressor clutch coil. I simply cut the old connector off my S14 harness and spliced in the new J30 connector pigtail. Since I'm using an E-fan setup with a fan controller, I spliced a fan trigger wire into the compressor clutch coil wire. Whenever the clutch engages, the E-fans come on.
As far as the chassis wiring goes, I can't offer any assistance. I have a Wiring Specialties harness which comes with all the chassis (M63/F3) to ECU wiring completed. I attempted to figure out how it was done, with some continuity checks, but quickly realized I would need to deloom and disassemble the wire harness. I don't want to do that just yet.
How can we contact you?
Had a couple questions
jdm60 is offline   Reply With Quote
