12-30-2022, 05:43 PM | #1 |
top mount setup/S13 SR valve cover catch can
Going top mount manifold soon, while waiting for parts to get in i already knew the stock oil collector/catch can wouldn't work anymore. With that being said I know people would go the S13.4 valve cover route and cut/weld the two together but i haven't had any luck finding a S14 SR cover for a decent price.
With that being said does anyone have an effective method/setup that works for the S13 SR cover with everything routed the correct way?? any info would help. I was looking at the Radium setup http://www.radiumauto.com/Catch-Can-...S13-P2031.aspx hadn't know anyone that runs it but it looks decent. Not 100% sure if that is the best route to replace the stock catch can setup.
If I had a dollar for every pet named "nismo" by a nissan owner Id be rich |
12-31-2022, 02:36 PM | #2 |
The S13 VC has a lack of baffling, so adding a can that does have baffling or even a medium for the oily vapor to attach to and collect would be fine.
You can use the turbo suction or an exhaust evac Venturi and check valve. The correct way to do this is lines from VC to catch can, to suction source. I do not like turbo inlet as oil vapor can reduce octane levels which could affect your tune. It also coats everything in the shit, including your intercooler.
01-01-2023, 01:33 AM | #3 |
Dont use a catch can, just measure the crankcase pressure and set it properly so the internal baffles work like OEM. Catch cans add volume and friction to the crankcase which further kills PCV action and that leads to oil leaking, poor oil drain, large oil droplets, increased blow-by, ring flutter, oil occluded ring pack, increased engine deposits and eventual wear and failure. Catch cans and excess lines are long-term health risks for a combustion engine.
Oil is good for the turbocharger that is what keeps the stock turbos alive on skylines supras and silvias for 250,000 miles, light oil film is protective. Metal needs oil to protect it from air. The oil wont pass the turbo if the crankcase pressure is set to OEM levels 0.5" to 1.5" Hg at wide open throttle. This is the mistake everybody makes, they don't measure and set it. If you install a fuel pressure regulator, you check the fuel pressure and set the fuel pressure right? If you install new tires, rad cap, transmission pump, oil pump, boost controller, they all have pressure values which need to be verified and set. The same goes for crankcase pressure. You change the PCV system by installing new turbos, air filters, engine breathing mods, whatever- its like installing a new fuel reg or tires or boost controller. Measure, set. |
01-01-2023, 03:03 AM | #4 | |
01-01-2023, 03:04 AM | #5 | |
01-01-2023, 08:00 AM | #6 | |
Many cars run catch cabs with no side effects. He looks at things from an OEM perspective. Negative crank case pressure helps seal rings better, keeps less oil in the intake that can gum up valves and helps an engine survive longer. OEMs have to keep all this oil in the motor for emissions purposes, performance engines don?t.
01-01-2023, 08:03 AM | #7 |
The black box isnt a catch can. It is an air/oil baffle. It provides a small amount of resistance to flow to prioritize the valve cover pressure drop and possibly preventing oil from exiting the oil pan and entering the PCV lines. I think they are worried oil being whipped up into a mist might be pulled out of the oil pan and into the intake. Notice it doesn't go between the turbo and valve cover, so any oil flow during WOT is going to ignore the black box. It was eliminated in the S14, I assume they improved the baffle in the oil pan. If you look at the black box its routed to the oil pan. If you need to remove it simply remove it and attach using a hose to the oil pan. I've done this way in the past without any issues. As long as the crankcase pressure is set properly there won't be large oil mist droplets suspended in the crankcase fluids. Air is a fluid.
To set the pressure you measure the crankcase pressure then adjust it at the air filter. Air filter provides pressure drop. If you removed the air filter from any engine in the world there is no more WOT Pressure drop for PCV and the engine will begin to blow oil from every seal and leaking dripping and fill the rings with oil causing carbon deposits etc... If you need an example video how to set and measure crankcase pressure check my build thread its the first video at the top and explanation |
01-01-2023, 10:22 AM | #8 | |
01-01-2023, 10:24 AM | #9 | |
01-01-2023, 11:07 AM | #10 | ||
If you add even 1" of hose it creates additional friction for fluid flow. It takes energy to move fluids. There are side effects to adding hose and volume to the crankcase. It doesn't matter whether OEM or race cars, all engines require PCV for ring function. Race cars use vacuum pumps to drive crankcase pressure into a vacuum so they can prioritize performance. Anybody without a source of vacuum for crankcase pressure system isn't just pushing oil- they are ruining their engine, circulating blow-by gas, creating deposits, trashing the block in the long term. It completely ruins the engine. "side effects" is the destruction of valuable block.
01-01-2023, 04:48 PM | #11 | |
01-01-2023, 06:34 PM | #12 |
Always pressure test forced induction setups
https://www.youtube.com/watch?v=w1sb5Y1J068&t=77s Always measure crankcase pressure at wide open throttle https://www.youtube.com/watch?v=0oRbfNPnHaI&t=1507s If you actually do these correctly, an OEM PCV setup for 2jz-gte, sr20det, rb2xdety, LS applications, will function 100% perfect I've successfully tuned ~250hp/liter these engines, sr20 500rwhp, 2jz 800rwhp, LS apps 1000rwhp, with OEM pcv hoses, lines, routes, for Daily Drivers Street/Strip high mileage setups 200k 300k miles some of them. LS apps I use the 2jz-gte Supra PCV valve, In my pressure tests the Chevrolet leaks. Sometimes the aftermarket PCV valves for Nissan and Toyota leak as well. You must test the entire plumbing the way I have shown in the video, do not trust the pcv valve without testing it. |
01-01-2023, 06:37 PM | #13 | |
https://motoiq.com/crankcase-ventila...d-n-a-edition/
01-02-2023, 02:56 AM | #14 | |
You are missing the part where lines create friction and volume dissipates pressure signal. If you add pipe it adds friction. Intercoolers add friction, they absorb kinetic energy which costs power, costs energy. Lines that feed oil add friction and slow oil flow they longer they get. Intake tubes that get longer add friction and increase pressure drop. Its fluid mechanics. Adding cans and lines will raise the pressure, they cause crankcase pressure. They work against the PCV system. Where does the vacuum signal originate from at wot? The air filter. That means for every line and can you add, now the air filter must become more restrictive to compensate. Its ANTI-Performance to add cans and lines. It takes ENERGY to move fluids through a hose, where does the energy come from? Its not free energy, no such thing. And finally the can and lines does nothing useful. Healthy engines don't spew oil mass enough to cause harm to anything. Not to any engine thats even been produced by any manufacturer- not turbo, natural aspirated, not corvette engines used for track duty, nothing ever came with a catch can and nothing ever needed one. They fooled you, fooled everyone, into thinking you need one. You see everybody else has one, so you assume you need one also. Its just a cheap part they can sell you, everybody has $50 or $100 to buy a catch can. Everybody can afford it. Nobody is actually measuring their crankcase pressure before and after to realize - Hey! It hurts the engine! People lack education to understand the relationship between pressure and oil droplet size, to understand differential pressure of the ring pack, the pressure goes behind the ring to hold it against the cylinder wall from above while pressure from the crankcase is trying to force the ring up, unseating it and creating excessive blow-by, lost sealing, oil occlusion. The two forces on the end of the power stroke play tug of war as the piston decends and the higher the crankcase pressure is the sooner the ring will lose tension and switch sides allowing oil to enter the 2nd and 1st ring pack, causing burnt carbon glue to gradually stick the rings and prevent them from turning. And I am only brushing the subject. |
01-02-2023, 06:36 AM | #15 | |
No factory car has. We aren’t talking factory cars here dude… You’re missing the point. We don’t care about a factory car setup. Also, a car with a dry sump setup (corvettes) doesn’t need a catch can, the crankcase is already under constant vacuum. The LS is also notorious for pooling oil in the heads under hard driving. RB’s are notorious for spewing oil out of their motors. Hence splash plates and added baffling systems. Even then they still need the catch can. Drag cars or any car modified for serious power have different ring gaps, which allow differing amounts of blow by than a factory car. Forged pistons, are a change from factory, which may allow more blow by. There are a thousand scenarios where one could use a catch can to prevent recirculating nasty by-product hydrocarbons through their motor. E85, another example, generates a lot of nasty stuff, I would rather have purged from my motor and sucked into a can.
01-02-2023, 04:30 PM | #16 |
You're missing the key factor here my guy. Engines don't need negative crankcase pressure through the crankcase at WOT. It is not necessary for engine longevity, it's just better for power and ring seal. Once you go back to cruising or idle, your PCV valve starts working again and pulls the contaminants out of the crankcase and into the intake manifold. On a racing vehicle this is different, but as you explained, most use vacuum pumps or are dry sump anyway.
Secondly, the whole point of aftermarket catch cans is to use a system that relieves crankcase pressure without having to use a restrictive air filter. Why the fuck would you want to use a restrictive filter on your performance engine? The whole point of what we do is to allow the engine to breathe and make more power/be more efficient. If you have vacuum in your intake pipe at WOT, you're engine is not making the power it could. Some of this is necessary evil of course, because air filtration is important, but a large air filter with more surface area will alleviate most of this. Lastly, it's pretty ironic that you go on and on about this, but don't even actually measure the pressure in real world figures in your video, it's just good enough for you that it moves down with the pipe attached and up with it disconnected. LOL. EDIT: I read your post below, and it’s quite intriguing, but you never mention how to set the crankcase pressure other than air filter restriction. Is this your only tool? Or a pill in the air filter line? What is the method you use to set this, and do you actually measure the value, or just go off map voltage like in your video?
Build: http://zilvia.net/f/showthread.php?t=643065 Friends don't let friends buy knock-offs. Last edited by PoorMans180SX; 01-02-2023 at 05:41 PM.. |
01-02-2023, 04:44 PM | #17 | |||||||
What I am getting at here is a perspective method for maintaining reliability. Stop thinking of your vehicle as a special or 'racing' vehicle no matter what power or function it has. Factory parts *are* racing parts, most are superior to anything aftermarket due to the decades of revisions and statistical interface that guided their ultimate function and production. Do you know how I got 50,000 miles from a Chevrolet engine that already has 200,000 miles to begin with, at 800brake horsepower, while keeping all the factory internals and drivetrain in a daily driver configuration? My mentality to keep all factory parts and understand their limitations and producing the environment in which they operate under the same conditions or similar to what the factory had intended. Quote:
Here my 2.5L RB 600rwhp NO catch can. No oil pooling. The RB has a head drainback modification which prevents oil from pooling in the head. This is the correct way to deal with oil accumulation in the engine baffles- NOT a catch can. Catch is a band-aid for idiots who don't know how to return the oil to the oil pan. Its how I can tell whether somebody actually knows what they are doing or not, instantly. Quote:
Gasses cannot be captured in catch can or any kind of solid vessel. It would be like trying to catch the helium from a balloon in a can- impossible. The only way to catch blow-by products is to dissolve them into engine oil, which is exactly what the PCV system is intended to prevent. You don't want combustion products to dissolve into engine oil because then they circulate around the engine causing deposits and atherosclerosis of oil venules/capillaries, leading to eventual wear and failure. Catch cans are the worst thing you can do to an engine crankcase system. Quote:
Again, its the worst possible thing you can do the crankcase of an engine |
01-03-2023, 04:33 AM | #18 |
Honestly, I'm impressed with the RB with no catch can. I edited my response above, but can you explain how you set crankcase pressure? Is there a way to do it without a restrictive air filter?
01-03-2023, 11:20 AM | #20 |
Its not a catch can, There is a return pathway for oil to the oil pan so it does not stagnate. Also, diesel is quite different from gasoline and their PCV system is not setup the way it would on gasoline engines. Nice try though lol @ comparing diesel to gasoline lol, those engines run maximum compression i.e. WOT , all the time, even during idle and cruise. If you want to compare it with gasoline engine then you must make apples to apples comparison e.g. If we hold a gasoline engine at WOT all the time and it makes maximum blow-by and compression and absolutely fills the crankcase constantly with blow-by gas and high flow throughput of course it will carry significantly more oil vapors through the PCV system and must have a separator to return the oil to the oil pan considering like diesel engines we expect it to reach 1,000,000 miles of driving at WOT... Go try 1,000,000 at WOT with a gasoline engine and see if you needed a separator for the oil. rofl
01-03-2023, 11:24 AM | #21 | |
If you size a turbocharger correctly to account for the loss associated with air filter pressure drop it does not influence final power output of the engine. It doesn't matter if there is some 1.5" Hg pressure drop because that will raise pressure ratio and if you look at modern turbocharger compressor maps as the pressure ratio increases they also flow more total volumetric rate (the maps LEAN to the right as pressure ratio is increasing). |
01-03-2023, 09:44 PM | #22 | |||||
01-04-2023, 08:18 AM | #23 | |
Your statement doesn't even make sense "You assume I'm trying to capture these gasses" ... "I want them removed" How are you removing them? lmao kids - go back to school man its time |
01-04-2023, 09:26 AM | #24 |
Reading comprehension kids. Go back and reread what system I?m using, then come back and have a chat with the grown ups.
01-04-2023, 11:57 AM | #25 |
FWIW, this is how I run mine with a regular S13 VC. Gleaned from a sticky thread posted here a few yrs back (https://zilvia.net/f/showthread.php?...ight=catch+can). Seems to do the trick, the 90-deg coming out of the VC minimizes oil vapor flow to the can, the line to the inlet pipe ensures negative pressure.
Mike
01-04-2023, 04:32 PM | #26 |
I think your additional lines and can is adding too much friction and causing high crankcase pressure, which is ruining the engine, creating additional blow-by and allowing blow-by to mix with engine oil and circulate around the engine causing deposits and leading to eventual wear and failure. Its probably worse than a breather.
You never measured the crankcase pressure or you would see the problem As we add lines or hose to that exit/entrance port on the valve cover, pressure rises inside the crankcase, all else equal. For example if you put a breather on the hose at 1 foot, then 10feet, then 100feet, then 10,000 feet, the highest pressure in the crankcase will be when the breather is at the end of a 10,000 feet of hose. The shortest route to the air filter (breather) is the lowest crankcase pressure. Remove all the extra lines and useless volume of can and it might save the motor. Otherwise it will eventually fail and the clogging of deposits cannot be washed out the engine will become un-reusable, non rebuild-able. Sure you will try to rebuild it but it will fail shortly again because the hard carbon forms diamond-like deposits in orifices which cannot be cleaned. I recommend do yourself a favor for peace of mind, get a $5.00 used 1-bar map sensor from any vehicle, install it to the valve cover (crankcase exit port on valve cover close to the crankcase) and attach a 5v signal source to it, using a $5 multi meter from harbor freight is fine, then read the map voltage at wide open throttle. Get a video. Voltage goes up, your engine is in trouble. Pressure over atmospheric is a scalar in the crankcase, like inside a tire, it has no vector, the molecules collide with all surfaces in all directions, that is what keeps a tire inflated at atmospheric pressure. There is a partial pressure of blow-by gas which will dissolve into engine oil and scalar pressure is forcing oil into engine seals leading to oil leaking. Furthermore at the end of power stroke scalar crankcase pressure forces early ring switching, causing extra blow-by and allowing oil to enter the ring pack and glue the ringpack, forming deposits on piston rings and interfering with ring to cylinder wall sealing. Its a slippery slope once you modified the crankcase without doing the measurements necessary. Like installing a fuel pressure gauge and never checking your fuel pressure. OR a boost controller. Crazy but everybody does it so it must be fine, right? Like smoking, everybody is smoking, must be fine? |
