Old 05-15-2023, 07:42 AM   #1
AKADriver
AKADriver's Avatar
Yes. They're the same Jatco RE4R01A trans. In fact other than the tailshaft housing/rear mount it was also used in a bunch of Mazdas. Theoretically that Jim Wolf KA/SR/RB/VG auto bellhousing-to-CD009 adapter kit might work to put a CD009 behind a Mazda 13B...!
The trans cooler lines may be plumbed differently I'm not sure. I've seen a couple different styles. But the connection points on the transmission case are the same so you could swap them over.
