Old 02-19-2023, 07:02 PM   #23851
Agamemnon
Agamemnon's Avatar
Originally Posted by jr_ss View Post
I believe the R35 unit is compatible with the S14. I am not sure about the S13.
https://m.youtube.com/watch?v=VwKh3dFcv3Y
https://trust-kikaku.myshopify.com/p...15-663101841s1
I saw that video as well. Are you thinking that the bracket with the bolt hole can come off and the pin will work with the stock s14 mount?
Old 02-20-2023, 04:40 AM   #23852
splitfire
splitfire is an unknown quantity at this point
Hello.
I'm putting together a suspension on the car. I have ST Suspensions anti-sway bars set.
Unfortunately bushings & sway bar links(which are actually long bolts) are worn and one front bushing bracket is torn apart.
Could anyone let me know exact size of bolts and where can I buy a replacement bracket?
splitfire is offline   Reply With Quote
Old 02-20-2023, 08:04 AM   #23853
LoSt180
LoSt180's Avatar
Trader Rating: (18)
LoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond reputeLoSt180 has a reputation beyond repute
Feedback Score: 18 reviews
Originally Posted by splitfire View Post
Hello.
Those bushings and end links are universal energy suspension parts. Take some measurements and compare to their online catalog:
End links: https://www.energysuspensionparts.co...-end-links.asp
Sway bar bushings: https://www.energysuspensionparts.co...r-bushings.asp
I don't know where to get just the brackets alone. I had to go thru a similar process when and unknown sway bar was included with a car my daughter bought.
LoSt180 is offline   Reply With Quote
Old 02-20-2023, 08:13 AM   #23854
jr_ss
No, I?m just assuming you wanted to replace the entire unit. Why would you want to bastardize something if it?s a bolt in solution?
Old 02-20-2023, 08:49 AM   #23855
LoSt180
LoSt180's Avatar
Trader Rating: (18)
I think the question was if the bracket on the door frame side was removable in the S14? On the S13/14 the door stopper is held in with a pin on that bracket, but the S15, 350Z, R35 stopper has the bracket as part of the stopper and simply bolts up inside the door jam.
Would be cool if a newer part was compatible, but that hinges on the bracket in the door jam being removable.
Old 02-20-2023, 10:23 AM   #23856
jr_ss
Ah, I misunderstood. I?ll take a deeper look when I head out to my car.
Old 02-20-2023, 12:29 PM   #23857
Agamemnon
Agamemnon's Avatar
Hello.
https://www.z1motorsports.com/front-...t-p-26787.html
https://parts.nissanusa.com/p/nissan...125-03161.html
Yes. Sorry for not making sense.
Old 02-20-2023, 01:55 PM   #23858
jr_ss
I?ll have to order a set to confirm whether or not the pin is the same diameter or not. It should be a pretty easy fix if not though. You don?t need a pin. A shanked bolt with the same OD as ID would suffice.
Old 02-21-2023, 07:18 AM   #23859
splitfire
Thank you for links. Unfortunately OEM bracket won't fit my aftermarket sway bar and measurements shown that brackets I have aren't Energy Suspension's. Most likely it's ST Suspension's product and seems like they are discontinued.
IMHO, my best choice is to buy a set of universal ES bushings and links and replace them all.
Old 03-10-2023, 06:54 AM   #23860
LoSt180
LoSt180's Avatar
Trader Rating: (18)
How well do hydraulic lifters from parts stores (or rock auto) hold up?
Bleeding lifters got rid of startup rattle, but the noise is back so I'm assuming I have at least two bad lifters. Two had a lot of air. New ones from Nissan are like $140/ea. Or should I try my luck with used ones? For a S15 SR.
Old 04-11-2023, 08:36 AM   #23861
adey
adey's Avatar
adey is an unknown quantity at this point
S13 vs S14/S15 rear subframe bolt sizes
Anyone know if the bolt sizes are the same between an S13 rear subframe vs. an S14 or S15 rear subframe? Specifically:
1) the bolts that hold the suspension arms to the subframe,
2) the nuts that hold the diff cover to the subframe (4 nuts for S13, or 2 nuts for S14)
3) the nuts/bolts on the diff carrier (main body) that go upwards into the subframe
Thanks!!
EDIT:
The part numbers are different, which is why I ask. Is there a length/thickness difference of the bolts (and hence nuts)? Thanks!
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 04-12-2023, 09:35 AM   #23862
AKADriver
AKADriver's Avatar
RUCA bolt is interchangeable but some S13s have a weird weighted bolt there hence the part number change. The S14 RUCA bolt also fits the S13 toe link.
Toe link bolt is longer for S14 but the same diameter/thread pitch. I investigated this in my alignment bolt thread over in tech. The RLCA bolt for several 2011+ Nissans 55226-JA01C fits in the S13 or S14 RUCA and S13 toe link for sure and I believe will also work in the S14 toe link (it's 10mm longer than the S13 toe link bolt). It's easier to find and cheaper. These all use the same nut. I used 42062-JA000 but it's just an M12x1.25 flanged lock nut.
Forward link bolt is interchangeable.
S14 RLCA bolts are longer but the same thread pitch, S13 nuts will work.
S14 is bigger.
S14 is longer.
Old 04-13-2023, 03:25 PM   #23863
AKADriver
AKADriver's Avatar
KA 5 speed: it looks like I have an oil leak through either my neutral position switch or the 5th gear switch. Can't tell which, they're both wet. FSM calls for thread sealant. I think I just used a dab of Permatex 59214. Did I just not use enough? Or is it more likely that the oil is just leaking right through the body of the switch, given that they're old and original? Both switches do work but I had to repair a wire on the 5th gear switch, I wonder if I ruined its internal seal with solder heat.
Old 04-13-2023, 06:50 PM   #23864
Ghostlive17
Ghostlive17 is an unknown quantity at this point
s14 ISR top mount ka24de Turbo kit opinions ?
Hi guys. I've been reading this forum for a while but never introduced myself, have a lot of good info on here but one thing I haven't noticed is no one has spoke about the TOP mount ISR kit. I know there's a bottom mount T2 kit from ISR that has been spoken about but they now have a T3 top mount with either a RSX3067,RSX3576, OR a RSX3582. Could I have some input on this kit and if anyone has run it with the full kit. I have my own blow off valve, and waste-gate, but tell me what you guys think of it I'll put the link in so you guys see exactly what I'm seeing.
https://www.aceupmotorsports.com/ka24de ... x-s13-s14/
FYI: this is my first time turbo-ing a car. I have a list of mods, I need to respectfully push no more than 10lbs of boost. My KA is completely stock besides exhaust, motor only has 133,000 miles on it. It's a '96 with a Kouki conversion all the way through. Also, this will be a "daily" so is 10lbs okay to push or should I start as 8lbs?
if this isn't the right spot to create this please transfer to where it belongs. Thank you for reading, eager on the feedback
Ghostlive17 is offline   Reply With Quote
Old 04-14-2023, 07:20 AM   #23865
AKADriver
AKADriver's Avatar
If you want a low boost turbo system on a stock block, a 'large frame' top mount T3 is way too much turbo. Respectfully, that turbo system is not in line with your engine or your goals.
I think there isn't much talk about it because most people who do build engines and turbo systems to that level in the S chassis world are past the point of kit builds and Chinese turbos. It's kind of a weird system from a marketing standpoint.
Your goals and wants and experience level are perfect for a bottom mount T2 based system that can use off the shelf parts and minimize fabrication. You will be much happier with something like an S15 replacement turbo or maybe like a GBC22-350 (but even that's a much more 'advanced' install, just because all the oil and coolant fittings are different from an old style T25/28).
Old 04-14-2023, 07:52 AM   #23866
Thursday7
Thursday7's Avatar
Thursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfectionThursday7 is close to perfection
Agreed with AKA. When fitting a turbocharger to a stock KA it's best to aim for low CFM (Psi is irrelevant when not referencing a specific turbocharger) turbo (GT2560 would be perfect) with emphasis on a good fuel system and ECU management.
No reason to go with top mount on a stock block IMO.
Thursday7 is offline   Reply With Quote
Old 04-14-2023, 06:54 PM   #23867
Ghostlive17
s14
AKA and Thursday you guys made good points, i think i will consider going that route then, for the turbo manifold should i look into getting the isr bottom mount or find a tomei mani, i looked at tomei website and it says its discontinued and preparing for "phase2" but i have no clue when that'll be, for the turbo im considering the gbc22-350, another question i have is if im running 8-12lbs of boost with stock internals will i be okay with a safc, a enthalpy tune, or get myself a standalone such as mspnp
ps; ill be running 550 injectors with a z32 maf
Old 04-20-2023, 03:03 PM   #23868
EFITTZY
EFITTZY's Avatar
EFITTZY is making a name for him/her selfEFITTZY is making a name for him/her self
ISR bottom mount mani would be sufficient, tomei mani if you want to ball out. You should be fine running an enthalpy tune, best yet have martin do it on the dyno. I would not recommend the MSPNP for Nissan applications.
(づ。◕‿‿◕。)づ T E A M B L O O M
EFITTZY is offline   Reply With Quote
Old 04-20-2023, 03:21 PM   #23869
Thursday7
Thursday7's Avatar
ISR manifold is fine. Just be aware that it will put the turbo 2 or so inches higher than where it would sit on an SR, so you need to do some fun stuff if using off the shelf SR downpipe pieces. I used 3 generic 2.75" ID 3-bolt flanges as spacers between the elbow and downpipe when I had a bottom mount KA-T w/ ISR manifold and SR downpipe pieces.
Enthalpy tune at a minimum. People love to hate, but they are fine so long as every other system in your car is up to snuff (emphasis on fueling like I said. I've blown up a few KA's w/ Enthalpy tune because I kept original fuel pump wiring like a dumbass). MSPNP treats me well on my SR but it wouldn't be my first option, it just came with my swap and a close friend is really talented with it. Nismotronic with speed density is probably your best sub-$1000 option. It looks like you're in Reading which is perfect. Hit up HDT automotive, Matt will set you straight as an arrow on a great setup, and he's super close to you. I also have a number of KA-T goodies I'd consider letting go and I'm not far from Reading. shoot me a PM if you'd like.
Old 04-25-2023, 05:43 AM   #23870
Thursday7
Thursday7's Avatar
For the first time in the 10 years I've owned my S13, this weekend it started giving me weird ebrake issues. Stock cables, PMU pads, GK tech seahorses, spin turn knob. It seems when drifting and using the handbrake at higher speeds (anything top of 2nd or faster) the handle almost locks itself in place (brakes engaged), which can be very sketchy when using it entering on a bank, which is how my home track is setup. I need to swiftly divert my attention to jostling/forcing it down, which is a pretty bad situation with multiple cars right behind you following your line.
I know it's not the knob pulling out because when this started happening, I made sure to only use the brake with my hand holding the button in (which is what the spin turn knob is supposed to prevent me having to do, but using it this way at least confirms it's not the spin turn knob causing the issue) and it didn't help the issue at all.
In my eyes, the culprit could either be the handle, cables, or calipers. I want to rule out the cables as they seem least likely to fail like this. I am leaning towards it being sticking calipers rather than the handle since speed seems to affect it, and I'm not really sure how the handle could lock anything given the spring is deactivated.
Anyone have input given my essay?
Old 04-25-2023, 07:42 AM   #23871
AKADriver
AKADriver's Avatar
Completely the opposite problem but after my car had been parked up for ages and I was overhauling the brake system I was having a hell of a time adjusting the rear calipers/parking brakes. I found that they had basically gotten overextended and wedged 'on' and my adjustments kept making it worse. I could see this happening intermittently when the brakes are hot with the extended lever arms. Not blaming the seahorses themselves, just that the extra leverage might make it easier to get in that state depending on how the pad thickness/rotor thickness/lever and cable adjustment/caliper adjustment all stack up.
Old 06-14-2023, 02:48 AM   #23872
Kylerkickass240
Kylerkickass240 is an unknown quantity at this point
does anyone know if the sun visors are all the same in s13 models? specifically wondering if vert visors are the same as coupe/hatch.
'92 vert, '10 accord coupe
Kylerkickass240 is offline   Reply With Quote
Old 06-14-2023, 08:42 AM   #23873
AKADriver
AKADriver's Avatar
Nope they're different. The vert visors don't extend as far towards the middle, the coupe/hb visors have extensions that try to cover the area above the mirror, the vert has its dome light there.
Old 06-14-2023, 08:32 PM   #23874
cole shoes
cole shoes is an unknown quantity at this point
I’m using GTR diff axles and hubs and I want to get a spare set of axles as I’ve had to replace them a couple times at the track. I’ve heard 300zx tt or q45 axles work can you guys verify years and sides I should be looking for?
cole shoes is offline   Reply With Quote
Old 06-22-2023, 11:09 PM   #23875
thermogod
thermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond reputethermogod has a reputation beyond repute
really need help figuring out what plug my 5spd speed sensor should be wired into. is it the plug near the crossmember?
or is it one of the two plugs that are past the crossmember and towards the steering rack?
i believe this is a full Wiring Specialties harness, and not an OEM lower harness, but i don't know enough to confirm.
i do not see this Wiring Specialties female plug for a male plug to wire into. this is a 5spd swapped 93 KA24DE convertible
yeah, that's a great steak, but it's not Cypher's steak.
thermogod is offline   Reply With Quote
Old 06-23-2023, 07:36 AM   #23876
AKADriver
AKADriver's Avatar
Those three connectors you have shown are for the neutral switch, 4th gear switch, and 5th gear switch. The ECU uses the neutral switch for something emissions related I can't recall, 4th and 5th gear switches are for the speed limiter.
The speed sensor connector is further up, right by the starter. The speed sensor normally has like an 18" long harness on it. It's weird.
Old 06-23-2023, 08:28 AM   #23877
LoSt180
LoSt180's Avatar
Trader Rating: (18)
Can confirm the speed sensor plugs in way up front near the starter.
Old 06-23-2023, 10:10 AM   #23878
thermogod
Thank you both. Found the plug, ordered the sensor-end of the plug.
Interesting that since my car was manual swapped, the odometer hasn't rolled past 114k, because the speed sensor wasn't plugged in. So it might have 250k. It might still have 114k. Who knows.
Old 07-04-2023, 08:55 AM   #23879
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
Anybody know the length of s13 manual seatbelts top bolts? The ones used to mount the bracket that swivels.
ZenkiKid is offline   Reply With Quote
Old 07-19-2023, 09:03 PM   #23880
DEGUZZI
DEGUZZI's Avatar
DEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to allDEGUZZI is a name known to all
Do I need this orifice for this line under the throttle body?
93 S13 KA24DE
If so, does its direction matter?
I believe the part number is 22321-D2200
IG: de_guzzi // Build Thread
DEGUZZI is online now   Reply With Quote
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki
