Old 10-21-2020, 01:44 PM   #961
TheRealSy90
TheRealSy90's Avatar
If you follow the Speetek guys on Instagram, they're constantly posting up broken "CD009" transmissions. And they say guys in Australia are breaking them all the time even lower horsepower cars. Slightly concerning.
Meanwhile I just finished installing my second Mazworx SR>VQ bellhousing kit. This time I'm not going to part the car out before driving it though..
Maxworx SR>VQ bellhousing / JK41B (g37) trans.
OsGiken TS2BD twin disc clutch/flywheel with specific bearing & sleeve.
new oem SR fork, fork retainer clip and throwout clip, Nismo pivot ball.
Ogura Racing adjustable clutch slave rod.
Such a good signature.
Old 11-25-2020, 01:26 PM   #962
Z_Roots
Z_Roots is an unknown quantity at this point
Great thread! I have a S13 getting the royal KA-T swap + CD009 from a '05 (external slave) and while I don't have any questions yet, I would like to see more build pictures, especially KA, external slave and Maverick adapter plate
Z_Roots is offline   Reply With Quote
Old 06-10-2021, 04:33 PM   #963
nameless_bk201
nameless_bk201 is an unknown quantity at this point
Im so sorry, but may be im only one who have disgusting noise from my jk41a with mazworx srvq bellhousing? trany after light refurbished (we replaced all bearings, seals and etc, components in very good condition)
nameless_bk201 is offline   Reply With Quote
Old 06-11-2021, 04:13 PM   #964
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
I'm not sure if it is posted somewhere in here but I recently used the Mazworx SR>CD009 bellhousing to convert a car. As a heads up DO NOT use the CD009 slave cylinder bolts on the conversion bell housing/SR slave cylinder. The CD bolts are a little longer and will interfere with the SR pressure plate.
C. Anderson is offline   Reply With Quote
Old 08-15-2021, 04:36 PM   #965
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
Hello guys. So my car won?t roll when the engine is off and it?s in gear with the clutch pushed in. Using the maverick motor sports adapter kit with a stock s13 master and slave. Any thoughts? Going to use a 03 350z slave and see what happens
corkscrew is offline   Reply With Quote
Old 08-16-2021, 07:59 AM   #966
tuzzio
tuzzio's Avatar
I have a Collins CD009 to s-chassis mount kit for sale. $100 shipped in the US
Old 08-16-2021, 11:21 AM   #967
slider2828
slider2828's Avatar
Ahhh. Thanks! I used EVERYTHING SR related on the CD009. Every bolt was from my SR.... Cool for the reminder
Turn and Burn!
Old 09-06-2021, 09:04 AM   #968
ph1tnessjunk1e
ph1tnessjunk1e is an unknown quantity at this point
Did you figure this out? I'm not yet at the point of trying to drive but I've filled the clutch lines with fluid and fully bled but it seems like the throw out bearing doesn't push enough on the pressure plate... I may come across the same problem.
ph1tnessjunk1e is offline   Reply With Quote
Old 09-11-2021, 10:04 PM   #969
corkscrew
corkscrew's Avatar
I ended up getting the sweet spot for the push rod adjustment. Likely your issue too. Just keep messing with the adjustment until it?s better
Old 09-28-2021, 11:57 PM   #970
sr20time
sr20time is an unknown quantity at this point
I am also running into an issues where the starter isn't wanting to disengage after cranking... s13 sr flywheel. sr starter, pretty sure its the collins plate. pretty much at a loss..
sr20time is offline   Reply With Quote
Old 09-29-2021, 07:10 AM   #971
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
Bad Starter?? If the plunger isn't fully retracting, just may very be sticking
RalliartRsX is offline   Reply With Quote
Old 10-03-2021, 05:30 PM   #972
t66-240
t66-240 is an unknown quantity at this point
Originally Posted by mr.nismo. View Post
So I got everything installed driveline wise. I had clearance issues with my drive shaft and shifter. Just throwing my setup on here for anyone looking to do the conversion.
SR20
Drift freaq motor mounts
Gk trans x member and mount
Rear subframe has solid riser bushings
Gk shifter and shaftmasters aluminum one piece abs shaft
Abs diff
Gk clearly lists their clearance at 90mm max. The widest part of the joint is 110mm, so obviously not going to work as is. The engine sits lower and subframe sits higher, giving the driveshaft a more straight line. The widest part is on the shaft side, and may have cleared with normal height engine mounts and subframe bushings (more tilt in the shaft). None the less, I shaved the dog leg down to clear. It's made of chromoly, and honestly don't see it breaking even with it being shaved.
Sent from my Galaxy Note 10+ using Tapatalk
Do you have a 1350 u-joint?
t66-240 is offline   Reply With Quote
Old 07-19-2022, 09:31 PM   #973
97kouki1J
97kouki1J is an unknown quantity at this point
Does anyone know the length of the driveshafts we need? I have a crazy idea of swapping a 350z diff and drive shaft in as well
97kouki1J is offline   Reply With Quote
Old 07-20-2022, 12:09 AM   #974
jr_ss
Not really a crazy idea. It?s been done before. Measure from output seal to pinion flange.
Old 07-20-2022, 07:05 AM   #975
AKADriver
AKADriver's Avatar
Also worth checking if a G35 coupe driveshaft fits. They use 2-piece shafts but you might be able to use just the front section with an S14 rear section.
Old 08-05-2022, 05:09 PM   #976
slider2828
slider2828's Avatar
I think Dakota Digital Released a one box easy wire for CD009 GPS Speed.
https://www.dakotadigital.com/index....rod/prd837.htm
SPEED 2 is a sine wave signal for most older speedometers.
Dakota Digital speedometers, and dash systems, can use either output.
Based on the manual, I can set it to a 16K PPM signal.....
https://www.dakotadigital.com/pdf/GPS-50-2.pdf
Then I wire it to the cluster. Once I have the signal wire from the Dakota, do I just wire back into the speed sensor harness?
I guess to where the sensor use to be which is on my KA24E harness, tranny harness Y/G wire?
Turn and Burn!
Old 08-10-2022, 05:26 PM   #977
TheRealSy90
Anyone else install the Mazworx VQ/SR bellhousing and using an OsGiken twin disc clutch? TS2BD if it needs to be specific.
The instructions say to machine 4mm off of the front of the sleeve that the slave cylinder slides on. I can't decide if I should or need to also machine off 4mm from the sleeve on the Mazworx bellhousing. They are about 1mm different in length...
Old 08-22-2022, 09:09 PM   #978
slider2828
slider2828's Avatar
Neutral Safety Switch and Reverse Switch. Is there a such thing as positive negative? Trying to hook into my S13 SR lower tranny harness....
Right now the starter isn't cranking, just 1 click when I turn the key and nothing....
Battery is good and tested. Starter is 100% good because its new AND I had autozone tested.
Switching out the Ignition Interlock / Relay, blue relay with two plugs on it in the passenger fender.
Thinking its NSS? Thanks!
Turn and Burn!
Old 10-29-2022, 03:28 PM   #979
slider2828
slider2828's Avatar
Just reporting back. Battery was good and starter was good. What happened was the relocated battery was grounded improperly...(don't ground anything to a raised bolt whole. it was tack welded by factory, so the ground was bad) Didn't need to jump through the rest....
To be back on topic, I will be attempting to install the new dakota module directly into the factory speedometer wiring soon
Turn and Burn!
Old 11-03-2022, 07:11 AM   #980
jr_ss
The signal has polarity, so if it doesn?t work at first, switch the wires around.
Old 12-27-2022, 10:14 PM   #981
slider2828
slider2828's Avatar
Hey all, need some help. How would you know if the clutch throwout bearing is fully disengaged? I have a ORC twin plate and I was supposed to use a 18mm carrier sleeve vs the stock 24mm.
So how can i check full disengagement?
Can I adjust the 6mm difference by changing the slave cylinder pin?
Orc and the old 240zs had adjustable slave cylinder pins.
Hoping I dun need to rip everything out again. Also are twin plates really loud? Definitely sounds like this. https://youtu.be/kSqsypA7e2g
Turn and Burn!
Old 12-28-2022, 02:09 PM   #982
slider2828
slider2828's Avatar
If this helps anyone in the future twin discs most of the time will need a shorter carrier. ORCand OSG twins use a 16 to 18mm carrier and our stock sr is 24mm. If you didnt put one in and in my case i didnt, i just cut about 6mm off the slave cylinder pin, dont forget to account for the cutoff wheel thickness a bit... Now i can better see a small air gap. Just make sure to put slop in the pedal and open the clutch reservoir and push everything back a few times to make sure the pin is in resting position. The readjust everything back.
Now the clutch engages at 1/4 of the way up and not like 5/8 of the way up....
Turn and Burn!
Old 12-29-2022, 09:15 AM   #983
C. Anderson
I know it is a little late but the throw out bearing collars are common discussion in the classic z forums. Nissan actually has several heights for the numerous versions of the FS Nissan transmissions. This is an example of some of the variations which may be helpful.
Old 12-29-2022, 04:01 PM   #984
slider2828
slider2828's Avatar
For perpetuity as long as zilvia is around. This is for ORC's older multiplate clutches 665D, 709D, 1000CC, and 2000CC and the required carriers with Nissan Part Numbers and their heights.
Turn and Burn!
Old 12-29-2022, 07:01 PM   #985
jr_ss
Exedy has the same thing listed on their site.
https://www.exedy-racing.com/racing/en/pro/repair.html
Old 08-10-2023, 10:25 PM   #986
slider2828
slider2828's Avatar
This is such a great thread, wanted to bump it. Drove the car around 1-3 gear no problem. Still in tuning phase so hopefully get more gears soon. Reverse is also fine.... I am running on a 4.3 final, I think its too much gear.... so will need to go back to the original 4.1..... at least I kept it.
also just purchase the dakota digital speed..... will report back if it all worked out to get speed on the speedometer.
Turn and Burn!
Old 08-11-2023, 08:25 AM   #987
kanyedian
kanyedian's Avatar
kanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nicekanyedian is just really nice
Can't have too much gear! It brings all the skidz! haha
I have an R154 paired with factory LSD S13 diff and I find it a decent combination. The trans has very long gears and the diff is shorter. Tbh I could go for an even shorter combo. I want more tyre spin and the 245s in the rear are just too much to break loose until I'm in boost.
Planned to go CD009 with LS1 and collins adapter but the RHD was interfering with mounting the engine and the firewall was too much in the way so switched to 1JZ/R154 swap
'93 RHD S13.4 1JZ | '22 Suzuki DR-Z400S | '18 Suzuki GSX-S750 | '07 Harley
kanyedian is offline   Reply With Quote
Old 08-14-2023, 11:29 AM   #988
slider2828
slider2828's Avatar
Lol a 4.3 with CD definitely will spin it up easy on a good turbo lol.... aren't zf tranny's all the jam now? like I rare hear about cd's any more
Turn and Burn!
Old 08-19-2023, 11:13 PM   #989
slider2828
slider2828's Avatar
Hey All,
Installed and it worked!!! The install was soooo easy. But you do need to remove the dash. Pulled constant 12v and acc 12v from the ignition tumbler. Then ground from anywhere. Then cut and wire in a wire from the dash (wire 6 y/lavendar) to speed 2 which is a sine wave and 16ppm setting.... now you have a gps and accelerometer speedo.
[img size=150]https://i.imgur.com/2iT0uXO.jpg[/img]
Turn and Burn!
Old 10-03-2023, 06:35 PM   #990
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
Delete post
mewantkouki is offline   Reply With Quote
