Old 12-31-2024, 05:24 PM   #1
91 240
91 240 is on a distinguished road
Hey Brandon, long time!!
Yeah I'm going run it through the Holley for now to see how it works. we'll see.
I got around to getting everything installed, however the Holley HP doesn't work with the OE sensors that are VR (variable reluctance)....sensor worked just fine but the Holley couldn't read it. Apparently on the Dominator can read VR sensors.
So i ended up picking up a hall effect sensor and made a bracket to read off the ABS ring.
It's got a built in test light to help make sure everythings working
https://youtube.com/shorts/nm-acHhoILQ
Took it out for a drive and everything is reading correctly. Hopefully I can do some testing later this weekend if the weather holds up.
91 240sx
03 Pathfinder
91 240 is offline   Reply With Quote
