Old 02-06-2005, 02:41 PM   #1
makoto
makoto's Avatar
makoto is an unknown quantity at this point
Send a message via AIM to makoto
question about valves on KA24de
i was wondering if there was any true specific order to the little covers taht cover the valvesprings....if certain ones belonged to a certain valve...or are the all universal and jsut the cams do the work?
umm here is a pic of wat im looking at....
makoto is offline   Reply With Quote
Old 02-06-2005, 02:43 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
They are shims, and they are valve specific. hope you didn't mix and match them.
Old 02-06-2005, 05:12 PM   #3
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
The top part is a retainer, or a rotator. It is not a shim, the shims go on the machined part where the spring sits. You should most likely not mix them up but it shouldn'tcause any problems.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 02-06-2005, 10:20 PM   #4
makoto
makoto's Avatar
hmm how do we know where to put it it back..???oh god.....im scared....lol.....but seriously what if we got new ones...??? how would we know...there are no markings.....
Old 02-06-2005, 10:39 PM   #5
Ritz S14
Ritz S14's Avatar
When you buy 24eggs... Use the egg carriage and label the lil boxes 1-24..that way when you remove yoru caps, you already have them ordered and ready to go during the install.
Ritz S14 is offline   Reply With Quote
Old 02-06-2005, 10:50 PM   #6
ledzeppelin240
The exhaust valve will sometimes have a rotator spring retainer that allows the valve to turn a small degree everytime. I'm not sure if that's how it is done on our engines. Otherwise they are all the same.
Old 02-07-2005, 09:08 PM   #7
makoto
makoto's Avatar
okok i just realy need to know cuz they felll out. what is the moter going to do if they are in the wrong place........ another thing are the intake any diffrent than the exaust ones.
Old 02-07-2005, 10:00 PM   #8
vtotech
vtotech is an unknown quantity at this point
Send a message via AIM to vtotech
place them back in any order, then when the head is completely back to gether you have to turn the cams and measure the valve lift. (i dont know how far the valve are acually suppost to move) but if everything fits tight and there is no slack and everythng seem to fit tight your ok, and no i dont believe the shims are different for intake and exhaust. you should call nissan and get a manual that is specific for the year 240 you have, it will cost you 60 bucks but it tells you everything about that motor.
vtotech is offline   Reply With Quote
Old 02-07-2005, 10:20 PM   #9
PinkPanther
PinkPanther's Avatar
PinkPanther is an unknown quantity at this point
Send a message via AIM to PinkPanther
KA
You need to set the engine at top dead center for no.1 cylinder and set the lash using shims under the lifters with the cams installed for the front four valves at the specific intake and exaust clearances specified in an FSM. Repeat for the other 3, setting engine at tdc for each. you will need a metric feeler gauge and a lifter compressor and a bunch of shims to do this successfully.
PinkPanther is offline   Reply With Quote
Old 02-07-2005, 10:28 PM   #10
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Yep. Fucking sucks for you.
-Jeff
Whatup?
