Old 02-07-2005, 11:37 PM   #1
qt_240
qt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really niceqt_240 is just really nice
Please Help Leaking Oil Sr20det..pix!!
hey guys.. im a total newby with the nissan and sr20(was a toyota,mitsubishi,honda guy).. im leaking oil..alot.. but im not sure if its the Headgasket.. i will be replacing it so0n.. but i would really like to know for sure if you guys have any ideas.. i did a search.. and i didnt find the answer specific to my problem.. i was told it was the oil pan gasket..but i dont think..so.. feedback would be great thankx !! just check out the pix..
qt_240 is offline   Reply With Quote
Old 02-07-2005, 11:45 PM   #2
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
oil pan needs new gasket or silicone. it might be front main seal?
This box is 400x200:
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
Old 02-07-2005, 11:47 PM   #3
qt_240
w0w.. that was fast!! great forum.. but yeah someone also told me about it might be the front main seal.. where is this ??
Old 02-08-2005, 12:08 AM   #4
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
I believe it is behind the crank pully.
Eternal_240Sx is offline   Reply With Quote
Old 02-08-2005, 03:32 AM   #5
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
That looks to me like one of the following only.
Listed in most likely order.
Front timing chain cover silicone needs replacement.
Front oil pump (main seal) seal needs replacement. Remove crank pulley, don loose the key way or youll be fowkd.
Lower oil pan silicone.
Upper oil pan silicone is leaking. (have to pull motor out so do that last if all else fails.
All of these are very common leakage problems on the sr. Make sure that when you reseal everything all surfaces have been scraped, cleaned, and scuffed with a scotch brite pad. Also make dead sure there is no oil on the mating surfaces.
Also at the area where the front timing chain cover meets the head, you must use silicone there as well.
Also. You must remove the valve cover, to acess the 2 10mm bolts going down into the timing chain front cover.
and dont worry you dont have to remove the timing chain.
How did you get an sr anyways?
blu808 is offline   Reply With Quote
Old 02-08-2005, 05:23 AM   #6
s13gonwild
s13gonwild is an unknown quantity at this point
is the silicone where the headgasket is?
s13gonwild is offline   Reply With Quote
Old 02-08-2005, 09:50 AM   #7
qt_240
hey man thankx.. thats really alot of help.. ill def. check those right away.. so basically u guys are sure its not the headgasket.. which is cool.. but im prolly going to be switching it anyways while im trying to fix this leak.. i dont get your question though..? how did i get an sr anyways?? umm i bought it??
Old 02-08-2005, 06:14 PM   #8
qt_240
bump~!!
Old 02-08-2005, 09:18 PM   #9
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
Your question has been answered already, why bump it. Its time to get dirty and fix it.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 02-08-2005, 11:19 PM   #10
qt_240
lol it is answered pretty much, just thought i could get more ideas..
Old 02-09-2005, 12:21 AM   #11
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
its gotta be up high..i dont think oil from the lower or upper oil pan would make it that high up the block.
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 02-09-2005, 04:26 AM   #12
s13gonwild
iono could it be wat looks to be silicone where the head gasket is?? i uploaded a pic showing what i talking about
Old 02-09-2005, 12:31 PM   #13
blu808
blu808's Avatar
That area where there is excessive silicone build up is part of the front cover for the timing chain, as i said it is most likely leaking from there. As you can see by the pic, the front cover has been removed for a timing chain job, or it was previously leaking which would indicate the ghetto rtv (silicone) The top part of the timing chain cover does mate with an extension of the head gasket. It is probibly leaking from there, but dont worry because this is not a pressurized area, so the head gasket would still be fine.
Just pull the front cover, clean the shit our of the mating surfaces, and use the blue rtv to seal it up.
