Old 02-17-2005, 09:56 AM   #1
destruction
destruction is an unknown quantity at this point
KA24DE AT to MT swap question
I have a whole 5spd S13 at home . and I also have a 97 with automatic shit-box. Can I use the s13 tranny on my s14 ?
destruction is offline   Reply With Quote
Old 02-17-2005, 11:05 AM   #2
vtotech
vtotech is an unknown quantity at this point
Send a message via AIM to vtotech
no you cant, the sensers are different and wont work, the tranny should bolt up but you wont get a speedometer reading. as for the other 2 sensers on the s13 tranny, i have no clue what they do. good luck
vtotech is offline   Reply With Quote
Old 02-17-2005, 11:51 AM   #3
orion::S14
orion::S14's Avatar
Yes, it bolts up to the motor.
But there are issues:
You will always have a SES/CEL b/c the S13 bellhousing does not have the mount for the OBD crank position sensor.
The speed sensors are different.
other sensors are neutral position switch, reverse light switch, and 5th gear switch, they can be hard-wired, plugs will not match.
See here for more:
http://ka24development.com/transmission_swap.html
And BTW...next time, search a little. I've personally posted this info NUMEROUS times in the past, as have many others.
- Brian
www.KA24DEvelopment.com
Old 02-17-2005, 08:21 PM   #4
zeek
zeek is an unknown quantity at this point
orion has good info, searching helps too
zeek is offline   Reply With Quote
