Old 03-01-2005, 06:14 PM   #1
asdf54
asdf54 is an unknown quantity at this point
Send a message via AIM to asdf54
car wont start
ive been trying to diagnos the problem but still no real luck
its an 89-90 240. i tested the fuel pump, injectors, spark plugs and spark plug wires, compression, fuel lines, and everything is workin. Can it be the regulator? Any help would be great, thanks a lot guys
asdf54 is offline   Reply With Quote
Old 03-01-2005, 06:23 PM   #2
SimpleS14
SimpleS14's Avatar
have you checked your starter?
SimpleS14 is offline   Reply With Quote
Old 03-01-2005, 06:27 PM   #3
chineseb0i
chineseb0i's Avatar
chineseb0i is an unknown quantity at this point
Send a message via AIM to chineseb0i
does it crank and want to crank over?
89 240sx Coupe
chineseb0i is offline   Reply With Quote
Old 03-01-2005, 08:02 PM   #4
NakayamaKiyoshi
NakayamaKiyoshi is an unknown quantity at this point
it cranks fine
IMG exceeds forum limit of 400x200
NakayamaKiyoshi is offline   Reply With Quote
Old 03-01-2005, 11:54 PM   #5
NakayamaKiyoshi
any ideas at all?
Old 03-02-2005, 03:24 PM   #6
squalsme
squalsme is an unknown quantity at this point
im having the same problem as you. read my post "s13 in desperate help" under the tech section... theres a list of stuff you can check. ill let you know once i fix it
squalsme is offline   Reply With Quote
Old 03-02-2005, 03:41 PM   #7
the head
the head's Avatar
are your fuel lines backwards
supposed to be filter to rail fpr to return
Old 03-02-2005, 05:09 PM   #8
NakayamaKiyoshi
the fuel lines are in the correct position
