Old 03-05-2005, 08:53 PM   #1
natedizzle
natedizzle is an unknown quantity at this point
Angry HELP my trunk wont open
i wanted to know if anyone has any suggestions on how to open my trunk? it wont even open with my key and the trunk latch doesnt work when i pull it. can anyone tell me what the problem is? thanks
natedizzle is offline   Reply With Quote
Old 03-05-2005, 09:46 PM   #2
tegasaurus
tegasaurus is an unknown quantity at this point
my POS13 does that. I can open it by using either, but the only way i can open it MYSELF is if i turn the key in the keyhole, and lift the hatch up with my hand, other wise there's no popping involved or anything...
not to jack the thread, but does anyone know how to get mine to pop? is there some sort of spring or somethin?
tegasaurus is offline   Reply With Quote
Old 03-05-2005, 09:54 PM   #3
s13gonwild
s13gonwild is an unknown quantity at this point
take your back serats off crawl in the trunk...and manually open it and replace the latch.
s13gonwild is offline   Reply With Quote
Old 03-05-2005, 10:08 PM   #4
007jpang
007jpang is an unknown quantity at this point
does replaceing the latch = new set of keys for the trunk???
April 24th, 1915
http://www.shockdrifting.com
007jpang is offline   Reply With Quote
Old 03-05-2005, 10:31 PM   #5
mhjrSR
mhjrSR is an unknown quantity at this point
To get the poping sound, all you have to do is loosen up the latch and push it down. I think its two 10mm or 12mm bolts, just loosen them push them all the way down and then tighten them again. It will get harder to close but it keeps the trunk closed properly.
Opportunites are never taken away..... there just given to someone else.
mhjrSR is offline   Reply With Quote
Old 03-06-2005, 12:46 AM   #6
nismod_rps13
nismod_rps13 is an unknown quantity at this point
Send a message via AIM to nismod_rps13
theres like two rubber things on each end of the hatch i believe. i think you can adjust those. also, you can just simply put something in the way of those rubber things. itll make the trunk pop easier.
'89 black xe
nismod_rps13 is offline   Reply With Quote
Old 03-06-2005, 01:52 AM   #7
9524tee
9524tee is an unknown quantity at this point
Send a message via AIM to 9524tee
try either pushing down on the trunk , or pulling up on it and relieving some weight from it , while turning the key at the same time , i had that problem . good luck .
9524tee is offline   Reply With Quote
Old 03-06-2005, 03:55 AM   #8
s13gonwild
no just the part that connects to the chassie part...it might be getting jammed.. so just replace it. or do what some of the members recomended.
Old 03-06-2005, 11:53 AM   #9
Andrew Bohan
loosen the latch and move it down a bit. someone already said that. no, not him, it was me last year.
http://www.zilvia.net/f/showthread.p...ht=hatch+latch
