simple question
hey guys, i have a red top , when it was stock it had a rough start, in the course of 6 months or so , i have upgraded the exhaust manifold, turbo outlet, downpipe , catback and greddy fmic. now eversince the intercooler upgrade, it has a very very very rough start, and dosent run as strong as one would think with all those upgrades, runnin stock 7 psi , and did a compression check , 150 accross the board .... so just please tell me , when i get tuned it will start better and be faster .... right ?
![]() Join Date: Jun 2004
hmm
what you have listed really arnt "upgrades" per say the cold start ect. What you really have to look at is that there IS SOMTHING WRONG! You must fix the problems before you do any more "uprgrades/tuning".
Bad starting issues can mostly be centered around wiring harness and spark delivery, especially MAF. Having some-one around who is versed in these types of problems (like me) would be a good thing. SO...check ECM for error codes. Check sensors for corect outputs (Sentra chiltons manual and voltmeter) check spark plugs. Check coil pack plug wires for corrosion/cracking check maf wires/plug for corrosion/cracking does the car idle right? The Idle Air Control Valve dictates cranking injection, is it possible this bad? feel like ![]() From here it sounds harness esq (internally) Recently Alot of the redtop harneses I have been seeing have been in pretty bad shape (internally) while externally they are ok. Maybe red tops are getting old in Japan/singapore/phillipines (where-ever these motors are REALLY coming from). But, this would be the start. John |
![]() Join Date: Apr 2004
I was having cold start issues too, it was fixed as soon as I found my boost leak. You just installed your intercooler so a leak may be your problem.
Hmmm....it starts up hard , but after it idles bouncy for a min. it idles soild at 800... i did relocate the battary to the trunk also , you think that could be an issue ? didnt think about boost leak ..... all the stuff up there johngriff listed are good, except i dunno about the internal condition of my harness? but thanks srmike , ill go check for more leaks
