Old 03-15-2002, 03:42 PM   #1
Thorpedo
Thorpedo is an unknown quantity at this point
Send a message via AIM to Thorpedo
So heres the deal....As you all know, my oil pump did lock up. I had it replaced. They drove it out of the bay, went to back it up in a parking spot and it died. THey tried starting it and it would turn over but not start up. &nbsp;they checked all the ignition stuff and it was all good. Then they tried checking the timing, they retarded it 90 degrees and it started..They say that the gear that is inside where the oil pump is at and the gear that the distributor is on is possibly broke. I know that there is pins down in there that hold everything together and that possibly when they pulled the distributor, the pin could of came out...What results would this give? &nbsp;Would the gears jump around and not allow the car to start. Also, the night before i checked my oil and it was clean and normal looking...now when he showed me at the shop, it was milky and disgusting looking. &nbsp; &nbsp;I'd like some feedback if i could...as i need to know what to do. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''>
1991 Coupe
::Current Status:: Disassembled
Future Status To be determined
hopefully reaching a track sometime this year!
Thorpedo is offline   Reply With Quote
Old 03-15-2002, 04:13 PM   #2
240sxracer
240sxracer is an unknown quantity at this point
"milky" sounds like you might have water in your oil.
1990 240sx FastBack
1965 Ford F100
240sxracer is offline   Reply With Quote
Old 03-15-2002, 04:47 PM   #3
SRskillaDET
SRskillaDET is an unknown quantity at this point
Yes, i know this but what would of caused that to happen? I only drove the car from my house to the shop which is the equivalent of less than a mile. Do you think that they could of possibly done something that caused whatever happened to happen. &nbsp;I mean, it was fine before it was at their shop.
'91 fastback base model
KA is dead at 202,186 miles
SRskillaDET is offline   Reply With Quote
Old 03-15-2002, 04:50 PM   #4
SRskillaDET
