Old 05-06-2005, 05:10 PM   #1
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
ok jeff some venting... done... yeah i did like them when they first came out... but after just researching and being the DIY type of guy i said screw it... i was gonna buy their manifold until u posted up that picture of how things lined up... obviously my mind changed, proprietary is true...for the main things...
i cant still believe their charging so much for the fuel setup when i paid 1/4 of the cost...
what numbers are u getting with ur kit jeff?
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 05-06-2005, 06:18 PM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
I don't have dyno numbers. I am having a boost issue. My old tial 35mm at 6.5psi on my revhard/t4 made solid 6.5psi. When I switched to Boost Designs/sc50 (t3/4), using the SAME wastegate, SAME spring, SAME vacuum source, it made 10psi. Figuring "Ok.. BD uses a generic 38mm gate, so I will too" I bought a tial 38/40 hybrid gate to hold boost solid, at 10.5psi spring.
Well.. I had to let off at ~60% throttle because I was making 14psi. With 50# injectors currently.. that's unacceptable.
I still haven't figured out the boost issue...
-Jeff
Whatup?
