Old 05-17-2005, 07:04 PM   #1
AMD 240
AMD 240 will become famous soon enoughAMD 240 will become famous soon enoughAMD 240 will become famous soon enoughAMD 240 will become famous soon enough
Send a message via AIM to AMD 240
white smoke....
ok....i got my first car like 2 or 3 weeks ago...i forget...i got it for 350 dollars. its a 89 240sx coupe. i have had this problem with the engine ever since i got it but i dont really car cuz im going to prolly get a CA18det.
white smoke flows out of the exhaust...when i checked the oil...steam came out of the oil cap. i checked the coolant level and it was dry so i fulled it up and started the car. five min later the rad was bone dry again...
im thinking that the lower timing chain guide broke, letting the chain hit the rad hose, putting a hole in it and letting coolant run into the oil pan...or the engine...
could it be something else? if so please help me....i want to fix this engine and make it last till i get the CA18 (a year or so)
AMD 240 is offline   Reply With Quote
Old 05-17-2005, 07:36 PM   #2
rim_bender
rim_bender is on the path to ruinrim_bender is on the path to ruinrim_bender is on the path to ruin
headgasket, is there oil in the coolant?
do a compression test to see if the gasket is blown
rim_bender is offline   Reply With Quote
Old 05-17-2005, 07:55 PM   #3
zero.counter
zero.counter's Avatar
zero.counter is making a name for him/her selfzero.counter is making a name for him/her self
Send a message via AIM to zero.counter
That is steam and you know what that means if coolant os gone and you see steam. Is the smell out of the exhaust sweet?
zero.counter is offline   Reply With Quote
Old 05-17-2005, 07:58 PM   #4
uno
uno is an unknown quantity at this point
Send a message via ICQ to uno
coolant burning!
at least head gasket is blown, if not more and the head cracked.
CA18DET t25, 440CC injectors, Greddy FMIC, Greddy Hot Pipe, Greddy Type RS Bov ,Greddy Turbo Outlet, Trust DP, Motoria 3" Catback , XS Tubular Manifold, Nismo AFPR ,Nismo Engine and Transmission Mounts ,Apex'i SAFC 2 Walbro 255lph, LSD, SPL Subframe Collars, Tein S Tech Springs, Tein Tie Rods, Upper Front and Rear Strut Tower Braces. Black 180sx wheels.
uno is offline   Reply With Quote
Old 05-17-2005, 09:20 PM   #5
AMD 240
the engine has 93,*** miles on it..so i dont think the head is cracked...im planning on replacing the headgasket and all the seals that go with it....but i dont think a crack would make the coolant drain that fast.
if you would like to see some pics of the car i could post them up...
Old 05-17-2005, 10:30 PM   #6
TOMY
TOMY is a well-known jackass
the engine is blown my friend. It is either the gasket or the rings have lost compression. Go to the store and get a compression tester for $15 and check for yourself. If coolent is not leaking from the bottem of the car, its going into the engine....therefore causing a Maple syrup smell. Coolant leaking into your engine is bad. Rebuilt the KA or buy an SR.... those are your options.
TOMY is offline   Reply With Quote
Old 05-17-2005, 10:37 PM   #7
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
Yeah the timing chain guide could be the problem, I have seen multiple front engine covers that are ruined. Is there coolant in your oil? Just because the engine only has 93,xxxmiles on it means nothing. You said it ran out of coolant, it has most likely been warped, aluminum just can't handle that.
You are burning coolant that is what the white smoke is so it is either, HG, cracked head or cracked block...So it is time to tear the engine down and find out what the problem is or get a new engine...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 05-18-2005, 07:02 AM   #8
AMD 240
ok you guys are scarng me...i dont have the money to get a CA18 yet
i will try to get my ka running right! i have to!
Old 05-18-2005, 07:47 AM   #9
uno
http://www.importperformanceparts.net/ and get the topline rebuild kit for like 150
Old 05-18-2005, 07:52 AM   #10
Big Daddy
Big Daddy is an unknown quantity at this point
it's your head gasket. i blew mine yesterday on the way to work.
Big Daddy is offline   Reply With Quote
Old 05-18-2005, 07:53 AM   #11
Big Daddy
exactly, mine has 88k and already blew the head gasket.
Old 05-18-2005, 07:53 AM   #12
TOMY
I just noticed your local. Go to Sound Performance in Bloomingdale if you want a definate answer. If it is blown, just spend $500 for a new KA.
Old 05-18-2005, 08:03 AM   #13
Big Daddy
Is that the rebuild kit for the KA or CA? if for the KA, could you please link me to the kit for an 89 240sx. thank you!
Old 05-18-2005, 08:12 AM   #14
uno
it's in frames, just click nissan->engine kits->topline oem rebuild-> pick your engine
Old 05-18-2005, 08:56 AM   #15
Big Daddy
cool thank you bro!
Old 05-18-2005, 09:35 AM   #16
uno
Originally Posted by Big Daddy
cool thank you bro!
anytime i know how it is for engines to get toated
Old 05-18-2005, 12:58 PM   #17
Big Daddy
and i just got her too. *sigh* had finished paying for her the night before.
Old 05-18-2005, 02:19 PM   #18
AMD 240
i got the car with the smoking problem...but i didnt and still dont car..i will be putting a ca in there soon...i dont know when but i will
Old 05-18-2005, 02:34 PM   #19
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
just put some coolant clogger .. dont know how its called but its supposed to seal the headgasket .. its a bandaid solution but it could work..
and if you think your gonna be out of trouble with an engine swap, youre wrong.. My swap didnt make any problem but i consider myself lucky that my engine was in great shape ...
F3600 is offline   Reply With Quote
Old 05-18-2005, 02:36 PM   #20
Big Daddy
if it's the same stuff i think you're talking about. called stop leak or something like that. HELLLLL NO clogs everything up, water pump, rad, thermostat, everything.
Old 05-18-2005, 02:47 PM   #21
AMD 240
the CA is a 15 to 16 year old engine. i know i will have to replace some stuff.
