Old 05-22-2005, 01:18 AM   #1
Vlade
Vlade is an unknown quantity at this point
s13 Rotor size needed for Z32 upgrade on S13?
Hi
I got hold of some used 26mm Z32 calipers... what are the exact dimensions of the rotors that will be needed on a S13. I still use a 4 lug hub.
This is what i think is needed
Diameter: 280mm
Original Height: 49mm
Original Thickness: 26mm
Minimum Thickness: 24.2mm
Center hole: 68mm
Lug holes: 4
Vlade is offline   Reply With Quote
Old 05-22-2005, 01:51 AM   #2
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Originally Posted by Vlade
Hi
Diameter: 280mm
Center hole: 68mm
Lug holes: 4
You'll need to redrill the 26mm 5 lug rotors for 4 lug.
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 05-22-2005, 02:05 AM   #3
RichthePoser
RichthePoser's Avatar
RichthePoser is an unknown quantity at this point
stock Z32 rotors, redrilled for 4-lug.
Rich
RichthePoser is offline   Reply With Quote
Old 05-22-2005, 01:00 PM   #4
Vlade
The reason why I ask the exact dimensions is because a rotor manufacturing company (www.powerbrake.co.za) close to me will manufacture my rotors to spec, I just need to supply them with the sizes...
The sizes I listed above are from a R32T / R33 and got the dimension from Disk Brake Austrailia not sure if that car uses the same Calipers as the Z32?
