Old 05-26-2005, 10:58 PM   #1
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
Atten: People With Hks Ssq Bov
ok i know that the ssq can change its sound by changing the little color thing inside. wat i want to know if the stock thing inside is wat makes this noise http://www.935motorsports.com/media/HKSssqvRX7.wmv . that whistle noise is wat im looking for. do i need to change the insert or does it do it with the stocker?
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 05-27-2005, 08:31 AM   #2
2JZGTE
2JZGTE's Avatar
2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute2JZGTE has a reputation beyond repute
Send a message via AIM to 2JZGTE Send a message via MSN to 2JZGTE
Those inserts don't change the sound a whole lot imo.
Just adjust the screw on top. If it's backed out, the air will release easier and will have a longer sound.
If the screw is tighter, the sound will be tighter and quicker as well. At least on my car this is how it works.
R35 GT-R, R32 GT-R, Supra, S13, S14, FD3S
2JZGTE is offline   Reply With Quote
Old 05-27-2005, 11:17 AM   #3
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
There are 2 inserts you can buy, one of them is identical to the stock one just different color. The other changes the sound slightly, not sure how much, but if you want that sound, thats how it sounds with the stock insert.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 05-27-2005, 04:20 PM   #4
WILDACEX187
cool thanx
Old 05-27-2005, 06:11 PM   #5
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
IIRC. the ssq is the older version and doesn't use an insert. The latest model is the SSQV which has different inserts.
SSQ: http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
SSQV: http://cgi.ebay.com/ebaymotors/ws/eB...category=33742
driftingisgay.com
nrg is offline   Reply With Quote
Old 06-11-2005, 10:47 PM   #6
WILDACEX187
does the ssq and the ssqv sound the same? ie. the whistle?
Old 06-12-2005, 03:24 PM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
shoot i changed turbos and my SSQ sounded different. Must be cause of the higher volune of air going tru it. Like 2JZ said, tighten it and itll change sounds.
Old 06-12-2005, 04:39 PM   #8
Nismo180
Nismo180's Avatar
Nismo180 is a well-known jackass
You guys do know that they didn't install that screw so you could change the sound right? It's so you can dial it in to your setup. Shouldn't be loose enough to leak at idle, but not much tighter than that to avoid boost surging into your closed TB plate.
Nismo180 is offline   Reply With Quote
Old 06-12-2005, 09:46 PM   #9
WILDACEX187
nobody knows about the old school sqv?
Old 06-13-2005, 03:33 AM   #10
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
Ik <3 My SSQV! Just had to chime in there.
DJPimpFlex is offline   Reply With Quote
