Old 05-31-2005, 02:21 PM   #1
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
problem with left-rear inner tire irregular wear (after Thunderhill CCW)
After my track day at Thunderhill, I noticed that my rear left tire was wearinng like someone peeling the rind of an orange. It's very noticable that more material on the very inside of the tire is worn down. I hope the pictures below clears up what I'm referring to:
don't mind the dust from the street.
Does anyone know why this is happening? the other tires are perfectly fine (other than a texture of an orange peel on every tire directly after the track runs)
Car Setup:
S14 kouki, Stock SE 16'' alloys, Falken Azenis RT-215 205/55/16 all around, open diff, stock suspension.
thanks
TurDz is offline   Reply With Quote
Old 05-31-2005, 02:28 PM   #2
OptionZero
OptionZero's Avatar
is that negative camber wear?
Old 05-31-2005, 03:37 PM   #3
ZK
ZK's Avatar
ZK is making a name for him/her selfZK is making a name for him/her selfZK is making a name for him/her self
Very normal. It's just melted rubber. It will eventually wear off and look like normal again. The reason it hasn't already is because it is at the edge of the tire and in normal driving you don't use the edge.
ZK is offline   Reply With Quote
Old 05-31-2005, 06:51 PM   #4
TurDz
TurDz's Avatar
would have any explanation on why it's on the rear left tire? does it have anything to do with the direction of the track that day?
Old 05-31-2005, 08:17 PM   #5
OptionZero
OptionZero's Avatar
i think most of the turns were left handers, and you have an open diff...maybe tahts why?
Old 06-01-2005, 12:20 AM   #6
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
You've got camber!
SochBAT is offline   Reply With Quote
Old 06-01-2005, 01:12 PM   #7
monkey7
monkey7's Avatar
monkey7 is making a name for him/her selfmonkey7 is making a name for him/her self
its open diff fun.
monkey7 is offline   Reply With Quote
