Old 05-30-2005, 09:42 AM   #1
sw20>>s14
sw20>>s14's Avatar
some tips on rust?
i was repairing all the suspension pieces i bent and had a major problem with topical rust seizing my parts...one that i couldnt overcome was the rust on the hub bearing to brake shield to spindle...i just couldnt tear it apart and from what i understand, the hub/bearing assembly should "slide out" with minimal force...
since im going 5 lug very soon, i was worried that i would have to deal with this problem X4...
so my question was: is there any product that penetrates rust and makes removing objects easier? just wondering if you guys have used products that actually work...i dunno, things like lubricants, grease, etc...
sw20>>s14 is offline   Reply With Quote
Old 05-30-2005, 09:45 AM   #2
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
pb blaster, wd40, etc.
papershot is offline   Reply With Quote
Old 05-30-2005, 09:46 AM   #3
Phlip
Yes, I look like that
Phlip's Avatar
PB Blaster works very well, 4.99 at O'Reilly's or whatever auto parts joint is closest to you... I found it more effective that WD40
Weirdo
And I write too!
Old 05-30-2005, 12:15 PM   #4
JDMs13
JDMs13 is an unknown quantity at this point
Send a message via MSN to JDMs13
deep creep......autozone, napa, pep-boys etc.....
JDMs13 is offline   Reply With Quote
Old 05-30-2005, 12:45 PM   #5
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
liquid wrench is pretty good too, altho i think PB blaster is a bit more effective.
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 05-30-2005, 03:11 PM   #6
chlatboy
chlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enoughchlatboy will become famous soon enough
WD40 and a good ole hammer!
If you dont know
SEARCH!!!
chlatboy is offline   Reply With Quote
Old 05-30-2005, 03:13 PM   #7
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Leave the rust, poorman's weight reduction!
SochBAT is offline   Reply With Quote
Old 05-31-2005, 03:16 AM   #8
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
i just did the z32 ebrake setup, and had the same issue... with rust.. it should come out not easily tho... just spray what ever and drive it out... in my case i sprayed silicone lube i had laying around.. let it sit for a few min...and then use a big ass socket as a driver and beat it loose... try not to damage any parts... and keep it solid.. i did this by myself.. so it can be done just gotta be persistent... once its out.. definetly should clean up the rust..
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-01-2005, 02:31 PM   #9
sw20>>s14
sw20>>s14's Avatar
thanks for all the suggestions, im gonna try all of the above...anything that will save my back is well worth the money...
hey, i was thinking. at first, i read that sentence wrong and thought you meant: you sprayed stuff and drove it around. do you think thatll work? ya know...lube it up and kinda loosen it up a 'lil? damn, girls are like cars...j/p to all you girls...
Old 06-01-2005, 02:46 PM   #10
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
[QUOTE=sw20>>s14]hey, i was thinking. at first, i read that sentence wrong and thought you meant: you sprayed stuff and drove it around. QUOTE]
I was thinking the same thing when I read it.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
Old 06-01-2005, 04:29 PM   #11
infinitexsound
noooooooooo not drive it around... spray lube and let it sit and penetrate...... then do what u gotta do...take for instance when ur doing the rears.... and u need to get the hub off the spindle and baccking plate... well u use a driver something about the same size of the bearing... and place it on the back of the bearing.. and u beat it to push the parts apart.... hence like a driver.. u do the same things when u replace u joints on the driveshaft
