Old 06-13-2005, 06:15 PM   #1
Xren17
Xren17 is an unknown quantity at this point
Need A S14 Driver Side Rear Caliper
I went to change my rear brakes and the driverside rear piston wouldn't turn back into the housing. Does anyone have one laying around in socal? I know I'm doing it right since the passenger side went in fine.
Thanks.
-Ren
Xren17 is offline   Reply With Quote
Old 06-13-2005, 06:20 PM   #2
sw20>>s14
sw20>>s14's Avatar
no one cares unless if theyre in the wtb section...are you twisting and using a c-clamp? i find that it make the job a whole lot easier...
sw20>>s14 is offline   Reply With Quote
Old 06-13-2005, 06:24 PM   #3
Xren17
I haven't tried the c-clamp combo. I'll give that a try.
Old 06-13-2005, 06:30 PM   #4
Ritz S14
Ritz S14's Avatar
C clamp wont do you squat on a rotating piston.
You'll have to turn the piston clockwise with a big ass flat head, needle nose pliers, or you can always use the correct tool.
Ritz S14 is offline   Reply With Quote
Old 06-13-2005, 06:34 PM   #5
Xren17
Like I said, the passenger went in fine. The driver side turns also but it just won't go back into the housing.
Old 06-13-2005, 06:40 PM   #6
Ritz S14
Ritz S14's Avatar
I don't think there is anything wrong with the caliper since it doesn't seem to be fronzen. Try turning it in the opposite direction?
I guess the clamp would be of use in this situation. Just that I never had to use one.
Old 06-13-2005, 07:31 PM   #7
Xren17
It went in after some persuasion with a hammer but somehow the hole where the bolt thread into is strip. This is not my day. Hopefully I can just retap it. If that doesn't work it's back to replacing the caliper.
-Ren
