Old 06-17-2005, 05:30 PM   #1
janko
janko is a well-known jackass
Rear wide fenders for S13
How much work is actually involved in installing these and how much coin? Have any of you done this?
Thanks
'92 G20
'96 240sx
janko is offline   Reply With Quote
Old 06-17-2005, 05:36 PM   #2
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
a lot of work, cost me 550 painted revited
SilviaDriver is offline   Reply With Quote
Old 06-17-2005, 05:40 PM   #3
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
You have to cut/bend the old fenders, and get wheels that actually look good under them. Otherwise its pretty simple, you can mold on the new ones, or rivet them on.
Generally cost 300-500ish. Check out version select or origin for overfenders. They generally come in 50mm but you can always modify them into something smaller.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 06-17-2005, 10:39 PM   #4
cheez80
cheez80 is an unknown quantity at this point
also, keep in mind, if you're planning on doing anything that involves smoke, you may need to weld the inner/outer stock fender together after it's been cut, so that smoke doesn't get into the cabin.
cheez80 is offline   Reply With Quote
