Old 03-25-2002, 07:34 PM   #1
allshow
allshow is an unknown quantity at this point
I got replies on how to fix the idle on my engine, such as: clean the maf, battery terminals, check for vacuum leaks.
Now, can someone give me a better description of where the maf is and what it looks like(is it a plug w/wires? is it a hose or tube?) also what and where is the aiv at? and where would vacuum leaks leak? Please help please!!!
allshow is offline   Reply With Quote
Old 03-25-2002, 07:55 PM   #2
hybrid240
hybrid240's Avatar
hybrid240 is an unknown quantity at this point
where is the MAF?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>??? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> are you joking? if you dont know where that is or what it is, you should probably take your car to a shop. you will must likely break something else. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
boostin through a neighborhood near you!
hybrid240 is offline   Reply With Quote
Old 03-25-2002, 08:25 PM   #3
geeaj
geeaj is an unknown quantity at this point
Mass air flow is the chunk of aluminum that is attached to your stock airbox. It has a connector harness pluged into it. It meters the incoming intake airflow.
Vacuum hoses are all over the place. Pull off a hose, if it sucks &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>, then its vacuum.
Beware the fury of a silent man, be more cautious of his silent farts....
geeaj is offline   Reply With Quote
Old 03-25-2002, 08:27 PM   #4
240sxspeedracer1
240sxspeedracer1 is an unknown quantity at this point
Send a message via AIM to 240sxspeedracer1
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (allshow @ Mar. 24 2002,9:34)</td></tr><tr><td id="QUOTE">I got replies on how to fix the idle on my engine, such as: clean the maf, battery terminals, check for vacuum leaks.
Now, can someone give me a better description of where the maf is and what it looks like(is it a plug w/wires? is it a hose or tube?) also what and where is the aiv at? and where would vacuum leaks leak? Please help please!!!</td></tr></table><span id='postcolor'>
the maf is a thing that looks like a metal peice.
It is located easily by following the intake pipe until u reach a metal peice that has like wires and crap on it. &nbsp;I guess if you wanna clean it, you can take it out and just use some tissue or something and wipe out whatever might be in there.
Next: the battery terminals is located where the battery is.
You know the negative and positive terminals?
Thats what they mean by terminals, its just simply the two wires that connect to the battery,
I guess if you wanted to clean that, you would just take some tissue or something and clean that off too.
Im not sure about vacuum leaks, somebody help him out on that one, <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
92 bmw 325i w/ m3 body kit
240sxspeedracer1 is offline   Reply With Quote
Old 03-25-2002, 08:46 PM   #5
samiam
samiam is an unknown quantity at this point
Send a message via Yahoo to samiam
I'm sorry, but I have to agree w/ Hybrid240. If you don't even have a general idea of what and where each of those parts are you should not even touch that car. Most of those should be taken care of or noticed each time you change your oil or do a minor tune-up. Take it to a mechanic or someone that might be able to show you.
I know everyone needs to learn sometime, but you might wanna waite till someone can take their time to show you. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
BuRn DuSt, EaT My RuBbeR !!
samiam is offline   Reply With Quote
Old 03-25-2002, 09:44 PM   #6
Arcane
Arcane is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (240sxspeedracer1 @ Mar. 25 2002,8:27)</td></tr><tr><td id="QUOTE">the maf is a thing that looks like a metal peice.
It is located easily by following the intake pipe until u reach a metal peice that has like wires and crap on it. I guess if you wanna clean it, you can take it out and just use some tissue or something and wipe out whatever might be in there.
Im not sure about vacuum leaks, somebody help him out on that one, <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''></td></tr></table><span id='postcolor'>
this might not be a good time to ask this then but...what's a battery??? &nbsp;
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''> &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/notify.gif" border="0" valign="absmiddle" alt=':notify:'>
it's called a life...maybe you should get one!!!
Arcane is offline   Reply With Quote
Old 03-25-2002, 11:15 PM   #7
allshow
ok...yes,maybe i don't work on cars to the point were i can just name parts just by looking at it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt=''> ..(thats why i chose the name 'allshow&#39<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> but the last time i went to a dealer and a shop, i had a bad experience w/them....but thanks to those people who were helpful!
Old 03-25-2002, 11:17 PM   #8
Alias
Alias is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (hybrid240 @ Mar. 25 2002,7:55)</td></tr><tr><td id="QUOTE">where is the MAF?<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>??? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> are you joking? if you dont know where that is or what it is, you should probably take your car to a shop. you will must likely break something else. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'></td></tr></table><span id='postcolor'>
Don't listen to him, its called "LEARNING". We all have to do it. I suggest picking up a Shop manual for your car. The library has a Chiltons, but they can be somewhat inacurate.
Alias is offline   Reply With Quote
Old 03-25-2002, 11:21 PM   #9
allshow
EXACTLY!! Alias....i do want to learn and because some people can easily figure out where things are at, they have to be sarcastic or a smart ass about it, but thanks for not making me feel dumb <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hehe.gif" border="0" valign="absmiddle" alt=':hehe:'>
Old 03-25-2002, 11:39 PM   #10
HotRodGuy
HotRodGuy is an unknown quantity at this point
Send a message via Yahoo to HotRodGuy
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Alias @ Mar. 26 2002,12:17)</td></tr><tr><td id="QUOTE">Don't listen to him, its called "LEARNING". We all have to do it. I suggest picking up a Shop manual for your car. The library has a Chiltons, but they can be somewhat inacurate.</td></tr></table><span id='postcolor'>
I agree, the first thang that you need to do is git yer hands on a service manual. Chiltons is good to start out with, but it's not very detailed. It should be fine for a "newbie" mechanic. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
The manual has a glossary that defines the accronyms that we all use. (MAF, TPS, EFI, and so on)
We all gota start sumwhare..... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cool.gif" border="0" valign="absmiddle" alt=''>
'91 240sx SE Fastback (sold to a kid who wrecked it)
'93 Chevy Silverado
'03 Chevy Cavalier
'05 Chevy Tahoe
If it ain't broke... don't fix it, just tweek on it and make it faster!
HotRodGuy is offline   Reply With Quote
Old 03-26-2002, 08:35 AM   #11
samiam
Well, the best you can do, is as everyone is telling you. And get a couple shop manuals and even an owners manual could help a little. Atleast everyone isnt screwing around like the oil change thread that's sum funnie chit. Just take your time and learn where the parts are. Most important is you need to find out what they do and how they work as a whole w/ the engine. Good Luck! I was just fu*#ing around earlier....as I did state you might try to get help from someone experienced like a friend or a father figure. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/notify.gif" border="0" valign="absmiddle" alt=':notify:'>
