Old 06-27-2005, 09:35 PM   #1
xka24detx
xka24detx is an unknown quantity at this point
KA good compression #'s?
i already tried searching and couldnt find anything. my friend and i were bored so we rented a compression guage from auto zone and got these readings. i remember reading somewhere about good #'s and bad ones, but i cant find them...
My ka24de
1=175
2=180
3=175
4=180
My friends ka24e (i might be off give or take 1 psi, im posting his by memory)
1=160
2=165
3=161
4=167
xka24detx is offline   Reply With Quote
Old 06-27-2005, 11:56 PM   #2
kandyflip445
kandyflip445's Avatar
Yours is good and your friends isn't too bad either.
My 240 vBgarage
Old 06-27-2005, 11:59 PM   #3
Munch
Munch's Avatar
Munch is an unknown quantity at this point
off of the 240sx.org faq (http://www.240sx.org/faq/articles/compression_test.htm)
"Compression Pressure kPa (kg/cm2, psi) / RPM
Standard = 1,236 (12.6, 179) / 300
Minimum = 1,040 (10.6, 151) / 300
Difference limit between cylinders = 98 (1.0, 14) / 300"
Munch is offline   Reply With Quote
Old 06-30-2005, 01:45 AM   #4
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
And those numbers are with WOT@300RPM, don't forget that...
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
Old 06-30-2005, 04:14 AM   #5
xka24detx
how do you do it at 3000rpm? the throttle was wide open, we did it the way we knew how to, cut fuel, remove all spark plugs, and crank the engine with the guage in each sparkplug hole
Old 06-30-2005, 06:38 AM   #6
docrice
docrice's Avatar
docrice is an unknown quantity at this point
Send a message via AIM to docrice
the specs are specified @ 300 rpm (not 3k), which is the speed your engine *should* crank at with the starter when the motor is warmed up. variation in that speed will cause variation in your numbers.
docrice is offline   Reply With Quote
Old 06-30-2005, 12:11 PM   #7
xka24detx
lol oops sry, it was late, i mis read it, but yeah throttle was wide open and i think it was at 300
