Old 07-02-2005, 07:03 PM   #1
matt0481
matt0481 is an unknown quantity at this point
Axle shaft length
I am installing the Z32 diff and got the axle shafts from a j30. With the car on jackstands, it looks like the right axle is too long. It looks like it's in a bind in the joint next to the diff. Is it because it isn't on the ground or what?
Thanks.
Matt
matt0481 is offline   Reply With Quote
Old 07-02-2005, 07:04 PM   #2
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
there's a difference in lenght from left and right
maybe you got two of the same side?
Maeda is offline   Reply With Quote
Old 07-02-2005, 07:27 PM   #3
matt0481
I measured them both and the right one is about 2"+ longer
Old 07-02-2005, 07:31 PM   #4
Maeda
Maeda's Avatar
you put them on the proper side, because it matters.
iirc shorter on left, longer on right, but thats off the top of my head.
Old 07-02-2005, 11:56 PM   #5
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
lol just try it...if it doesnt fit then try puting it on the other side =)
IAM_SO_sLOw is offline   Reply With Quote
Old 07-03-2005, 03:07 AM   #6
johngriff
johngriff's Avatar
you will be able to visable see which axle (longer vs shorter) should go where when the diff is in, cause it sits to the side a little.
Good luck
John Griff
Old 07-03-2005, 10:44 AM   #7
matt0481
I have them on the correct side. Maybe it's because the vehicle is on jackstands and the suspension is unloaded.
Old 07-03-2005, 03:37 PM   #8
johngriff
johngriff's Avatar
i would guess as much!!
You cool!
