Old 08-03-2005, 10:53 AM   #1
cr571k
cr571k is an unknown quantity at this point
Bad Fuel Pump?
I'm trying to see if my fuel pump is bad.
Okay so I'm reading the fsm and it doesn't say which wire is ground or which wire is positive in the fsm.
I was just going to run a wire with a 10 amp fuse from + on battery to the positve of fuel pump and then ground on fuel pump to ground on car to see if the fuel pump is bad?
Any help on which color wires I should be looking for coming from the fuel from the fuel pump?
Right now coming from the fuel pump in order from the back of the car to the front is Black, White w/purple strip, Yellow, Blue w/red strip and then Yellow w/Blue strip.
It's a 91 if that matters
One day I will have a turbo KA
Tein Flex coilover suspension, Tein Pillowball tension rods, 5zigen FNO1RC wheels in 17x7 and 17x8, wrapped in Falken st115s, AEM short ram intake , Hotshot Headers, HKS Hi Power Exhaust, Corbeau CR1 seats with Scroth harnesses, B&M short throw shifter
cr571k is offline   Reply With Quote
Old 08-03-2005, 11:29 AM   #2
240meowth
240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all240meowth is a name known to all
Send a message via AIM to 240meowth
What makes you think your fuel pump is bad? Car won't start?
240meowth is offline   Reply With Quote
Old 08-03-2005, 01:13 PM   #3
cr571k
Sorry for not explaining what I've already tested. My battery is good. I have spark. When I turned the key with the fuel line off the top of my filter no fuel came out which to me would mean there is something wrong with fuel delivery from the pump forward. Correct?
