Old 08-15-2005, 10:10 AM   #1
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Removing ABS
Hey everyone. My friend needs a new master cylinder and calipers (mc leaks, caliper froze up), but has ABS. I have a non-ABS parts car. So, rather than him buying from the dealership/parts people, we think bypassing ABS is the way to go.
I just don't know exactly what's required to do. I'm thinking remove the ABS box, replace all the hardlines, and the calipers. Is this correct/incorrect? Any downsides to removing ABS? He lives in Michigan, and I personally stop a car faster without ABS using threshold braking than the ABS does. And.. when sliding in snow, the ABS never locks up.. it keeps modulating, which slows the car down more slowly. So don't tell me ABS rocks please. I'm looking for mechanical or electrical reasons that removing the box and replacing lines/calipers/master cylinder will/won't work.
-Jeff
Whatup?
Old 08-15-2005, 03:07 PM   #2
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
i think thats all you need, non abs brake MC, and the non abs hard lines and your set. I just got them from a junk yard, not gonna swap them out until i do a swap (easier to change brake hard lines with motor out)
Sfourteen
dct223 is offline   Reply With Quote
Old 08-15-2005, 03:31 PM   #3
projectRDM
projectRDM's Avatar
-Jeff
All he needs is the MC. Calipers can swap over from the non-ABS car. Buy the MC versus swapping and bypassing the ABS unless he really doesn't want it. There's two ABS master cylinders here locally at Z Car Atlanta, 770.446.1090, buy one of those for $50 shipped and it's fixed.
If you really want to ditch the ABS, swap the MC and hardlines, then remove the actuator and control unit.
FORMERLY R240NA
Old 08-15-2005, 09:29 PM   #4
TheSparo
Location: Athens/Chattanooga/ Cookeville/Morristown, TN
TheSparo is an unknown quantity at this point
Send a message via AIM to TheSparo
i think you need to swap the abs brake booster, i am actually about to do the same project, i've figured all you need is the MC, Booster, Hardlines, and the proportioning valve... im pretty sure the non abd has a smaller booster...
89 240 SR powered...
ummm i promise its stock
TheSparo is offline   Reply With Quote
Old 08-16-2005, 12:38 PM   #5
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
ABS brake booster is bigger, however you dont need to sswap it out. I did this swap. ABS unit was faulty and leaked. All you need is the master cylindar, and the hard lines. No need to change the calipers. Remove the ABS unit as well. Saves like 25lbs. and a lot of space. You need all the hard lines, both front and the 1 rear.
Thats it.
autobahNESSA is offline   Reply With Quote
Old 08-16-2005, 01:00 PM   #6
ibanezxguy
ibanezxguy is an unknown quantity at this point
Send a message via AIM to ibanezxguy
hey im also in the process of pulling my abs, all wiring and sensors have been pulled. But does anybody know the part numbers for the hard lines? I looked at a dealership computer but its not clear at all on which part is which.
ibanezxguy is offline   Reply With Quote
Old 08-16-2005, 01:18 PM   #7
dct223
dct223's Avatar
hrm... yea i can see how it may be confusing on what the part # is.. but you should just check out junk yards, or peopel parting out their s14's, i bet dealer will charge you an arm and a leg for 3 hard lines
Sfourteen
Old 08-16-2005, 07:53 PM   #8
TheSparo
are s14 and s13 brake lines interchangeable? and why can't you use the abs rear lines?
Old 01-01-2006, 09:07 PM   #9
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
my master cylinder/accuator work perfectly fine with no leaks but i want to disable the system from controlling my braking. is there a way to just disable the system all together just electronically (fuse, harness disconnection, etc??)
sorry to revive an old thread but...i wouldn't want to make a whole new post about this..thanks guys
sean350z is offline   Reply With Quote
Old 01-02-2006, 10:23 AM   #10
projectRDM
projectRDM's Avatar
Technically yes, the control unit will just see a fault and go into safe mode, but if you really don't plan on using it you can easily save 25lbs and pull it. Dealer hardlines are pretty cheap and you only need the three shorter ones on the firewall.
FORMERLY R240NA
Old 01-02-2006, 02:11 PM   #11
Sexy_Ninja
Sexy_Ninja's Avatar
Sexy_Ninja is an unknown quantity at this point
you could pull the abs fuse if you wanna jus do that instead.
Sexy_Ninja is offline   Reply With Quote
