maybe this will help
Hey when I did my 5 speed swap I didn't unplug a thing under the steering column, I got pissed cause I took all that apart for nothing. I have a 1990 and in the engine people said to splice those 2 plugs or something, which didnt work. On mine, there were 2 plugs around the fuse box. One of the plugs I found was directly under the fuse box. Just stick your hand under there and feel for a plug. the three plugs are the same style connector. if what I wrote is confusing, pm me and I will rewrite it.
sorry, heres a cleaner version I think the three plugs were something like plug 1 on fuse box: white wire and black/yellow. plug 2 on fuse box: white wire and black white, the 3rd plug had black white and black yellow (I think this one was on the tranny side of the wires)
Just match up the colors. Just so you know the white wire is the 12v constant, the black/yellow is a starter wire, and the black/white is a starter wire as well. So it would be a good idea to disconnect the battery, leave the key out of the ignition, car out of gear, and make sure there are no idiots near your steering column and keys.
Back after 10 years...
