Old 04-09-2002, 11:00 PM   #1
luey02
luey02 is an unknown quantity at this point
people say wheel clearance gets smaller for coilover setup?  Or wider wheel can fit??  Bottom line, wider or skinnier wheels can fit on coilover assembly compare to stock setup?!  Anyone know?  by how much?
thanks
K. Lu
luey02 is offline   Reply With Quote
Old 04-09-2002, 11:16 PM   #2
teampulse
teampulse's Avatar
teampulse is an unknown quantity at this point
Send a message via Yahoo to teampulse
well with my coilovers i have the stock 15 inch steels on there and in the front it only clears by like 1/4 of an inch, i mean you cant even get your finger in there.  in the back it clears by plenty.  so up front to get wider rims you must get the right offset like +35 or less and/ or get spacers and for the back im not sure how wide you can go and still clear but it isnt much of a problem like the front.
- jared -
Motorcycle Track days!
teampulse is offline   Reply With Quote
Old 04-10-2002, 12:34 AM   #3
jupiterl
jupiterl's Avatar
jupiterl is an unknown quantity at this point
Send a message via ICQ to jupiterl
Hey what sup , loey02
If you have coilover, don't even bother putting on anything more than 42 offset in the front. Remeber the RX7 rims that I have ? They don't fit in the front , I need a 20mm spacer to get a safe clearance.
SR20det redtop, 205hp Stock
jupiterl is offline   Reply With Quote
Old 04-10-2002, 01:42 AM   #4
jskim9
jskim9 is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (jupiterl @ April 09 2002,02:34)</td></tr><tr><td id="QUOTE">Hey what sup , loey02
If you have coilover, don't even bother putting on anything more than 42 offset in the front. Remeber the RX7 rims that I have ? They don't fit in the front , I need a 20mm spacer to get a safe clearance.</td></tr></table><span id='postcolor'>
which rx7 rims do you have? the FD? do you know what the offset is on those? My friend needs that info
also, 42offset definitely wouldn't clear it. You're gonna have to go down into the ~20mm. If you have access, go check out an Option or Carboy magazine, most of the setups have C/O and they tell you specfiics on the rims they got as well.
*(insert clever comment here)*
jskim9 is offline   Reply With Quote
Old 04-10-2002, 06:19 AM   #5
luey02
thank you fellows
K. Lu
