Old 10-12-2005, 07:54 PM   #1
240sxballa
240sxballa is an unknown quantity at this point
silvia front grill
i got a silvia grill for my s14 but i cant seem to take off the old grill without breaking it, the screws are up in a spot where u cant get a tool in there to un bolt iy , and i cant even see what type of screw it is?, i can only feel the screw , so my Q is has neone taken off the grill b4? if so how do you unbolt it?
240sxballa is offline   Reply With Quote
Old 10-12-2005, 07:57 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Moved to Tech as this is a TECHNICAL QUESTION.
Old 10-12-2005, 09:56 PM   #3
projectRDM
projectRDM's Avatar
S14- remove two top clips, pull straight up.
S14a- turn four clips half turn, pull straight out.
It's not brain surgery man.
FORMERLY R240NA
Old 10-12-2005, 10:01 PM   #4
theicecreamdan
theicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfectiontheicecreamdan is close to perfection
Send a message via AIM to theicecreamdan
2 screws on top, tabs on the bottom, try sliding a flat screwdriver under and push the tabs in as you pull up, be gentle but firm.
Originally Posted by malcolm_x
Be peaceful, be courteous, obey the law, respect everyone; but if someone puts his hand on you, send him to the cemetery.
theicecreamdan is offline   Reply With Quote
