#1 | |
I'll have to see what the rod bearings look like when I get that far, but thanks. |
Check the cylinders for out of round and if they are there was most likely piston slap in the cylinder. Check the piston for a collapsed skirt, which would cause piston slap as well as excessive clearance.
The absence of carbon or washed effect is from a coolant leak into that cylinder. Check to see if the rod bearings have even load wear, also if you have a micrometer check to see if the rod journals and rods are out of round, or elongated.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power. Looking for: JDM S13 OEM Sideskirts |
I've got the motor pulled out and halfway torn apart, I have to wait on a crank pulley puller to get the rest out, but at least I know now what the issue is with the motor.
![]() Lots of metal shavings. Rod #1 has about 3-4mm of play to it on the crank. ![]() Here's the main piece I've found so far. Looks like rod bearing to me. I'll probably add a few more pictures once I get the oil pump off and the rest of the assembly removed. Thanks for reading.
*image exceeds forum limits* -Moderation |
