Old 11-25-2005, 08:23 PM   #1
massscene
massscene's Avatar
massscene is an unknown quantity at this point
SR Dynod My Stock S13 Redtop Tonite
Well I was pleasantly surprised. At stock boost no boost controller I made 204 whp. 193 wtq. Only mods are a z32 maf, clutch and 3 inch turbo back exhaust. timing was left stock. 2 bad news things- i blew my water pump while I was on the dyno. (my guess is that there was air in the system) other bad thing- my car after I shut it off when its warm it doesnt want to start for a few minutes. weirdest thing though. If i unplug one or two of my injectors it will start sooner. hmmmmmmmmm. I must say I am upset i didint get to take it for a beat run but hey its meant to be. Im still missing a few things though so this is for the best. anyone else suprised by these numbers? i definatly thing 230-235 whp is possible at 14 lbs.
Black S14 Base Model Converted to SE w/ extra goodies.
massscene is offline   Reply With Quote
Old 11-25-2005, 08:46 PM   #2
TheTimanator
TheTimanator's Avatar
what are you using to control the z32 maf? also, are you running the the factory side mount intercooler?
post the dyno sheet!
Old 11-25-2005, 08:51 PM   #3
monkeyspeed
monkeyspeed is an unknown quantity at this point
your shoud replace your coolant temp sensor...the sensor is telling the ecu false info and it's dumping a ton of fuel, which would explain why it starts sooner when you unplug some of the injectors. check the ecu for codes, check the wiring and then check the sensor. my stock sr at stock boost with 3" back made 200whp and 194wtq. good luck with everything...
monkeyspeed is offline   Reply With Quote
Old 11-25-2005, 09:55 PM   #4
broken_s13
broken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enoughbroken_s13 will become famous soon enough
THose are some good numbers (in my opinion). How many miles are on your engine? Can you post up any charts.
broken_s13 is offline   Reply With Quote
Old 11-25-2005, 10:43 PM   #5
sdtouge
sdtouge can only hope to improve
if you hvae turbo back exhuast, clutch, and maf, your sr isnt stock.
sdtouge is offline   Reply With Quote
Old 11-25-2005, 10:45 PM   #6
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
i made 195whp and 211wtq at 12psi on stock smic, down pipe, exhaust, intake, and z32 fuel.
driftingisgay.com
nrg is offline   Reply With Quote
Old 11-26-2005, 11:31 AM   #7
mr_240sx
mr_240sx's Avatar
i made 213rwhp and forget the torque numbers but i was running stock except for 3inch downpipe, no cat, and 3 inch apex'i n1 cat-back, greddy fmic and safc II and 10psi.
mr_240sx is offline   Reply With Quote
Old 11-26-2005, 11:39 AM   #8
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
TheTimanator " what you useing to control the z32 maf"
either way that motor is not stock, unles u mean stock block.
that seems a little high in the #'s for lacking a front mount, do you have a water sprayer?, AFC to increase the fuel to make that kind of power at stock boost?
I put down 184hp, filter, downpipe, high flow cat, 3in exhaust. 20hp from a z32 maf?
I know with safc, frontmount it can make 20whp more then my setup. but just a maf itself?
autobahNESSA is offline   Reply With Quote
Old 11-26-2005, 01:16 PM   #9
TheTimanator
thats what i was getting at. you have to have something to control it so i was thinking that maybe he had some tuning done with a a/f controller or something. i could see those numbers with a fmic
from what i understand you don't actually gain power from running a Z32 maf it's just not limited as much as the factory maf
Old 11-27-2005, 12:19 AM   #10
Silverbullet
Silverbullet's Avatar
Silverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really niceSilverbullet is just really nice
Send a message via AIM to Silverbullet
is it that hard to believe that he has a good strong running motor? lol. look at the location, MA. It's cold up there.
My friend with a WRX had a stock top mount IC. It heatsoaked like a bitch durring the spring and summer just city driving. Now, the IC is ALWAYS icey cold.
HouseBuyers365.com
Originally Posted by Flybert
Go back to whatever Honda forum you came from.
Silverbullet is offline   Reply With Quote
Old 11-27-2005, 12:58 AM   #11
kuramaya
kuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfectionkuramaya is close to perfection
numbers sound about right for an S13 RT
ZEROYON WEBSITE IS HOMO
NEW SITE: blacklinux.com/innersanctum/index.php
kuramaya is offline   Reply With Quote
Old 11-28-2005, 12:12 AM   #12
95zilvia
95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light95zilvia is a glorious beacon of light
What kind of dyno machines were these run on?
I know that Mustang Dynos and Dynojets have different readings with the latter having higher numbers.
95zilvia is offline   Reply With Quote
Old 11-28-2005, 07:49 AM   #13
massscene
massscene's Avatar
well its funny you say that the dyno I go to is a mustang dyno. it reads about 15% lower than a dyno jet. I put down 178 whp on the mustang dyno. but corrected to dyno jet its about 204whp. and I have an e manage running the z32 maf. i did no tuning at all on the e manage. my tuner tunes conservative so he was a little suprised at how lean of a mixture the stock ecu settings are it was pretty much 12.5 across the board under boost and i was at the stock boost (what ever it may be some say 7 some say 11. vaccum from wastegate to intercooler piping). as for the intercooler it is from and old volvo. but believe me its a good setup. i will have to get pics. its a hundred times better then the stock sidemount. its almost as if it was made for this car. its goes where the radatior goes and the inlet is directly acroos from the turbo and the outlet is directly across from the throttle body.
Old 11-28-2005, 04:54 PM   #14
mr_240sx
mr_240sx's Avatar
well i hit 213rwhp but it was on a mustang dyno. whatever that means
Old 11-28-2005, 07:17 PM   #15
95zilvia
that means you hit 213 rwhp on a mustang
and like, if u did ur dyno on a dynojet, u woulda hit like, 250 rwhp or something.
Old 11-28-2005, 10:06 PM   #16
HaLo
from Canada, eh!
HaLo's Avatar
I got the same amount...178 whp on a T25 tuned at 7psi on a SAFC... 12-12.5 A/G across the board. same modz. What was your numbers before the tuning?
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 11-30-2005, 05:26 AM   #17
massscene
massscene's Avatar
i really didnt tune much. i only used the e manage to control the z32 maf. the a/f is at the factory settings as is the timing.
Old 11-30-2005, 06:06 AM   #18
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
Damn nice #'s
My friend did 200hp and 201tq on a stock s13 blacktop, on 12psi, exhaust and intake.
What do you guys think a stock s15 sr, on 8psi, exhaust, dumppipe, intake, and frontmount would put down? I am about to drive it this afternoon for the first time so I cant make a guesstimation just yet. I dont even know what its boosting, but I am predicting 8psi.
TheSnail is offline   Reply With Quote
Old 11-30-2005, 07:55 PM   #19
neilsan
neilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-knownneilsan is making his/her stupidity well-known
Get pics for the Volvo intercooler!
I assume it's from a 740, i dont know about ~1985 240gl-t's but i do know know about half the 740 turbo's dont have an intercooler. which is messed up from a technical standpoint.
btw 740 turbo's are a good source for used decent size oil coolers
neilsan is offline   Reply With Quote
Old 12-01-2005, 06:05 AM   #20
massscene
massscene's Avatar
damn i got to take pics. when I tell people there like o you just have a volvo intercooler. then they see it and they think its sick!
