Old 12-11-2005, 01:07 PM   #1
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
Tuning with Safc ll
EDITED for content instead of making a new thread
I know the safc has a ton of features and stuff to tune with, but im not really good at using all of them yet. I was trying to figure out it i could use the safc to "tune out" some little problems...
When i let off the gas, in any gear, so i can coast, the car jerks around and rpms bounce around. Can i tune something so it will keep constant fuel at low throttle? (similiar to the decel settings i have set up for the atmospheric bov) so the car doesnt have a fit when i let off the gas.
Also, today driving around... when you come to a stop, the rpms drop very low (~500) and then bounce back to idle. I just changed the decel/open bov settings earlier, so i havent tested if that fixed it or not.
any help would be appreciated
nsn240 is offline   Reply With Quote
Old 12-11-2005, 05:27 PM   #2
mr_240sx
mr_240sx's Avatar
im pretty sure my hotwire is either 0101 or 0606
mr_240sx is offline   Reply With Quote
Old 12-12-2005, 01:23 PM   #3
nsn240
nsn240's Avatar
06 06 is the one you need. thanks alot, i appreciate it!
Old 12-12-2005, 09:25 PM   #4
nsn240
nsn240's Avatar
bump with some new questions above.
Old 12-13-2005, 08:51 PM   #5
2_fast_240
2_fast_240's Avatar
2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore2_fast_240 is not welcome here anymore
the rpms dropping down real low could just be caused by to much slack in the throttle cable. mine had the same problems except it would even stall sometimes when i pushed in the clutch and hit the brakes real hard. if i remember right there is some kind of adjusting screw you can just tighten up.
2_fast_240 is offline   Reply With Quote
Old 12-14-2005, 12:32 AM   #6
pwhitersxs
pwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enough
Send a message via AIM to pwhitersxs
Make sure your timing is set correctly and you can adjust the iacv if your idle is always low. That procedure is in the fsm at www.zeroyon.com Also, your dec air settings should fix that, I know on here or on freshalloy is a procedure to set the dec air settings.
s13 sr20det
pwhitersxs is offline   Reply With Quote
Old 12-14-2005, 09:28 AM   #7
nsn240
nsn240's Avatar
i still have to check on the throttle cable slack... but i tighten up the bov and that really helped with the big drop. The decel air settings dont really seem to do anything though. I also went -4% at idle (1000) and it runs much smoother with that, still some lumpyness though
