![]() Join Date: Jan 2005
Anyone with 550s, Z32, and S-AFC?
A few issues have come up and I have to step back my "upgrades" a little bit. I was wondering what kind of drivability people have with just an S-AFC tuning for Z32 and 550s. Also, what kind of power.
my planned setup: GT2871R .64 A/R 555s Z32 S-AFC II FPR all the other support piping mods. etc. |
Man w/ CTSV & a Car Seat
That should be the biggest set of injectors you can run with a s-afc. If you run any bigger, then your better of going ECU re-tune. Im running 740cc on the same turbo with an Enthalpy Rom Tune.
I have all those minus the fpr and i made 300whp and 280 wtq at only 18psi. Im going back for more tuning and cranking the boost some more since im not even in the efficiency range of the turbo yet. drivability is awesome with this set-up. the power comes on soo smooth and holds to redline.
![]() Join Date: May 2003
yeah im in the mist of using this set up. my mines ecu was programmed for stock 370'cc fpr ca18det so i cant boost much on it. think it was rated at 15 psi or something like that.
![]() Join Date: Jul 2005
i was planning on running a very similar setup, and i was told to get a tune from scott and use the SAFC for fine tunning. Its basically plug and play, and his tunes are very reliable.
#7 | |
S13Rymos- thanks, that's ecactly what I needed to know. |
I am assuming a stock t25 turbo since it says planned setup which I think means you dont have the gt2871r on yet.You should not worry about power because your timing will be kind of screwed up. As you probably know, as you scale back fuel through the afc, it also adds timing. I know I had 600cc injectors with just an afc for about 2 wks before I got a chipped ecu and it was hell. With 550's it will be driveable but it will be better once you get a true tune, but it will be driveable.
If you have the gt2871r turbo on there, it will be a little better, but a tune will really dial in your settings for optimum horsepower.
s13 sr20det |
#10 | |
Are you kidding? The whole original setup was designed around the turbo ![]() |
#11 | |
![]() Join Date: Nov 2003
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
hmmm i'm trying to figure this out. starting a new thread, so I don't thread jack. some tuning questions.
http://www.zilvia.net/f/showthread.p...430#post878430 |
Well dont put the injectors in until you get the turbo. This way thats one less problem, so if something does go wrong you know that it will be the z32 maf or the safc or regulator. Plus this way your timing wont get screwed. Good luck.
s13 sr20det |
#14 |
How would you guys go about tuning this? I have all the stuff put together now and sitting in my garage. If I just bolt it all on and reset the ECU would it stand a 3k or less drive to the tuners? If you didn't have a flatbed how would you go about getting it all on and tuned? Don't forget my boost controller I'd hate to show up to the tuners with no idea where my boost is
#15 |
I'm running:
GT2871R HKS Top-Feed fuel rail RC 750cc injectors HKS FPR Z32 Apexi AVCR Apexi SAFC RS Enthalpy ROM Tune (Scott is an amazing man) **I would suggest getting a base tune from Enthalpy. It's about $500 but the best bet is pay it, otherwise you can go standalone and that costs a lot more loot. Goodluck! ![]()
- Jay ![]() WTB: Nothing at the moment. LEWL WTS: Everything sold, thanks folks! |
#16 |
![]() Join Date: Dec 2004
it's do able..i know. dont go above 550's since the safc can only take away so much fuel though....
ZEROYON WEBSITE IS HOMO NEW SITE: blacklinux.com/innersanctum/index.php |
