Old 01-08-2006, 04:26 PM   #1
c240sx13
c240sx13 can only hope to improve
rear driver side brake wore down faster than rear passanger??
Yeah just like the title says, my rear driver side brakes wore down completely while my rear passenger brake pads were still full of life. Why do you think this happened? I used the key to push the piston back on both sides? Did I not bleed it correctly? Im going to change both of them again, before I do though, what do you guys think I did wrong so I wont do it again??
c240sx13 is offline   Reply With Quote
Old 01-08-2006, 06:23 PM   #2
tripleb
tripleb's Avatar
tripleb is a well-known jackass
Send a message via AIM to tripleb Send a message via Yahoo to tripleb
have you replaced the calipers in the past. thats usually a symptom that the caliper is not disengaging all the way and dragging so it wears the pads unevenly.
or the other one is not engaging at all
" I am a firm believer in a ruling clas........espcially since i rule"
tripleb is offline   Reply With Quote
Old 01-08-2006, 07:07 PM   #3
c240sx13
ahh crap it did unwear the pad unevenly!! nooo am i gonna need to replace the caliper soon!??!!?
Old 01-08-2006, 09:19 PM   #4
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
did you make sure the piston notch is sitting on the brake pads correctly?Mine wern't sitting correctly on one side, and that side wore down much quicker than the other side. Now i think they're fine.
driftingisgay.com
nrg is offline   Reply With Quote
Old 01-08-2006, 09:24 PM   #5
projectRDM
projectRDM's Avatar
Caliper is seized. Second most common problem on 240s. Replace as a pair.
FORMERLY R240NA
Old 01-08-2006, 09:26 PM   #6
tripleb
tripleb's Avatar
yeah its common on the rears of z31 300zx's to
mainly because of age. but i am positive it s bad caliper i woudl replace them in a par as recommended above just so you know both are good
Old 01-08-2006, 09:50 PM   #7
andrewmp6
andrewmp6 can only hope to improve
its the cailper or maybe a wheel bearing or unblanced wheel
andrewmp6 is offline   Reply With Quote
Old 01-08-2006, 11:15 PM   #8
jdmsilvia909
jdmsilvia909's Avatar
jdmsilvia909 is an unknown quantity at this point
just replace the calipers
*Image(s) exceed(s) forum limit, strike 2*
-Moderation
R.I.P. 1990 NISSAN 240SX...U WILL NOT BE FORGOTTEN
jdmsilvia909 is offline   Reply With Quote
Old 01-08-2006, 11:19 PM   #9
c240sx13
calipers for sale anyone?? haha
Old 01-09-2006, 12:34 AM   #10
g6civcx
g6civcx's Avatar
Check to see if either caliper is dragging, and that the piston is not pitted. This is very common on the Nissan.
You can get remanufactured calipers for about $60 apiece. It's not that expensive.
Old 01-09-2006, 01:47 AM   #11
andrewmp6
get one from auto zone pepboys or any auto parts store
