Old 01-09-2006, 06:32 PM   #8
smithers584
smithers584 is an unknown quantity at this point
well if you are like me, its because you have the stock turbo. you could be running out of fuel if you are on the stock pump or if you have a bad coil pack that would explain it. we would need more info about the set up and tuning to tell cuz it could be a lot of things: plugs could be causing it, try gapping them at .28. When you pulled your old plugs did they show any signs of a lean condition or rich? have you tuned your car? what kind of boost controler are you using? do you have a boost gauge? have you paid attention to see if your boost is dropping off?
smithers584 is offline   Reply With Quote
