Old 01-18-2006, 02:03 AM   #1
dog3gtr
dog3gtr is an unknown quantity at this point
Does anyone make Urethane Subframe bushing collars??
My S14 comes up w/ common problem..
when you shift, rear subframe makes sound..
But then, If I just put in Subframe bushing collars, I don't need to change subframe bushings right?
I've been reading posts here whole day..
I use my car for track/also daily so aluminum sounds hard core for me.
So, I'm looking for Urethane Subframe bushing collars..but can't find it anywhere.
Can anyone help me out?
dog3gtr is offline   Reply With Quote
Old 01-18-2006, 02:06 AM   #2
Dousan_PG
Dousan_PG's Avatar
tanabe does
whiteline does
thats all i can think of off the top of my head..
Aaron
Pink GodziRa
Old 01-18-2006, 02:37 AM   #3
TurDz
TurDz's Avatar
TurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the roughTurDz is a jewel in the rough
Send a message via AIM to TurDz
Peak Performance?
search eBay for "s14 urethane subframe" or look for distributors.
TurDz is offline   Reply With Quote
Old 01-18-2006, 04:23 AM   #4
andrewmp6
andrewmp6 can only hope to improve
just go to splparts.com they have them
andrewmp6 is offline   Reply With Quote
Old 01-18-2006, 06:57 AM   #5
GonadSX
GonadSX is an unknown quantity at this point
I have the Whiteline ones. Takes minutes to install. A little difference but I still expreience wheel hop now and then.
Gautam :: Google Specialist :: www.my240.com
GonadSX is offline   Reply With Quote
Old 01-18-2006, 09:40 AM   #6
dog3gtr
Are we talking about this one?
SPL says this is subframe tilt spacers..
Or this one?
Pdm-racing says it's Rear Nissan Sub-Frame Align and Lock Kit..
Also, If I get spacers, I don't need subframe bushings right?
Thank you guys..
Old 01-18-2006, 10:56 AM   #7
Dousan_PG
Dousan_PG's Avatar
same thing they are subframe spacers
Aaron
Pink GodziRa
Old 01-18-2006, 01:22 PM   #8
allmotorKA
allmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really niceallmotorKA is just really nice
If you don't want spacers but want urethane bushings, look into Peak Performance like TurDz said. Here is a link that came up in google...
http://www.store.yahoo.com/phase2mot...epeursubu.html
allmotorKA is offline   Reply With Quote
Old 01-18-2006, 01:54 PM   #9
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
I have the Whiteline ones on my hatch. Noticed improvement on traction and the rear feels a bit higher. Still have some hop though.
A friend has HEs and alluminum collars (nice and stiff) and likes the ride just fine.
-Juan
Old 01-19-2006, 01:28 AM   #10
GLoBaLReBeL420
GLoBaLReBeL420 is an unknown quantity at this point
I got Tein SD and after i put on the spl collar kit, i can't even tell you the difference it made. My back end is actually sticking to the ground. To ass-out, I have to actually clutch kick, or brake initiate. While before, I could just turn the wheel and press gas and the back end slid out.
GLoBaLReBeL420 is offline   Reply With Quote
Old 01-19-2006, 01:54 AM   #11
TurDz
TurDz's Avatar
Oh, so you have to remove the old rubber bushings to put in the Peak Performance ones? I had no idea...
The PP ones are shaped just like solid metal subframe spacers (Kazama, T3, ebay style) and I thought they slip on like the rest. guess not?
Old 01-19-2006, 02:13 AM   #12
chmercer
chmercer's Avatar
just get the aluminum ones like everybody else. seriously you will hardly be able to tell a difference much less loose any ride quality. putting subframe collars on an old bushing is like the same as having brand new factory bushings (kindof?).
chmercer is offline   Reply With Quote
Old 01-19-2006, 02:25 AM   #13
A Spec Products
A Spec Products's Avatar
tanabe discontinued theirs
but yeah, other options as listed above
aluminum is better imo, but either does the job
A SPEC PRODUCTS CORP
Old 01-19-2006, 02:40 AM   #14
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
If you have a broken OEM bushing in your subframe. Bushing collars/spacer will not fix the problem. You need to press/cut out your old bushings and replace with OEM ones or ES bushings. This is the problem I'm having right now. I installed the spacers on my subframe, a month later; one of my oem bushings broke. I can now move my subframe with my hand lol.
driftingisgay.com
nrg is offline   Reply With Quote
Old 01-19-2006, 02:53 AM   #15
WILDACEX187
WILDACEX187's Avatar
WILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond reputeWILDACEX187 has a reputation beyond repute
Send a message via AIM to WILDACEX187
does anybody experience understeer with the aluminum ones since u have more traction at back?
SR POWA COUPE LUVVV!!!
WILDACEX187 is offline   Reply With Quote
Old 01-19-2006, 09:43 AM   #16
Dousan_PG
Dousan_PG's Avatar
definitely NOT
Aaron
Pink GodziRa
Old 01-19-2006, 10:25 AM   #17
WILDACEX187
ok thank you
Old 01-19-2006, 10:59 AM   #18
EchoOfSilence
EchoOfSilence's Avatar
EchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant futureEchoOfSilence has a brilliant future
Send a message via AIM to EchoOfSilence
Are these SCCA legal? I'm not sure about the aluminum ones either. It would suck if you're put in a higher class like Unlimited just because you have subframe collars/spacers
Petition Nissan to Make the IDx on http://IDxClub.co !
EchoOfSilence is offline   Reply With Quote
Old 01-19-2006, 11:40 AM   #19
S14DB
AFC #1
S14DB's Avatar
I got these Nylon ones off ebay for cheap:
Unless you get the Aluminum ones with Notches cut out. You have to drop the whole sub-frame. Which is easy if you know the trick to it.
Old 01-19-2006, 01:01 PM   #20
dog3gtr
are you sure this is bushings? not spacers?
I'm looking for bushings now, but it seems everyone makes only spacers.
I can't find it even in ebay.
Can anyone give me a link for urethane subframe bushings for S14?
Thank you
Old 01-19-2006, 01:07 PM   #21
Dousan_PG
Dousan_PG's Avatar
you want bushings?
SPLPARTS.COM
those guys have nearly everything
what they dont hvae, can probably get.
Aaron
Pink GodziRa
Old 01-19-2006, 01:10 PM   #22
allmotorKA
No, you're right, they slip in like the Kazama style.
Old 01-19-2006, 01:18 PM   #23
allmotorKA
Thank you
They call them bushings but they are inserts that fit just like the ones S14DB posted. These inserts fill the gap of the stock bushings. I call the SPL or Whiteline "spacers" because people will put them to change the angle of the subframe...ie put the spacers in the top/front only etc.
Old 01-19-2006, 01:43 PM   #24
dog3gtr
Sorry for bitching but i'm confused now.
what I want is "urethane subframe bushing" which is inserted into subframe.
Sth that I have to remove stock old bushings to put in new "urethane subframe bushing"
I don't want spacers for now..
Splparts.com doesn't have one.
I thought this was it
but I guess it's just like spacers?
Old 01-19-2006, 01:54 PM   #25
Dousan_PG
Dousan_PG's Avatar
email spl
they sell solid
im sure they can get you urethane type.
Aaron
Pink GodziRa
Old 01-19-2006, 10:44 PM   #26
S14DB
AFC #1
S14DB's Avatar
Nismo makes replacement bushings. You have to take the sub-frame completely off the car with everything off. Then press out the old sleeves and press in the Nismo units. It's a major operation.
Most peoples bushings get soft after time and why they get the spacers like I have to reduce the slop.
The whiteline bushings are to change the angle of the sub-frame to change the squat characteristics of the IRS.
Unless your stock bushings are so shot to the point were the center pin doesn't stay in. I would get spacers to stiffen it up.
