Old 01-19-2006, 11:50 PM   #1
Boost Monkey
Boost Monkey is an unknown quantity at this point
Question grinding noise in reverse gear
hey guys, i need some help. when i put the car in reverse, and let out the clutch, the tranny area will make a grinding noise while the car starts moving backwards. this only happens in reverse. no grinds going into gear either. just only the grinding noise when the car is actually moving backwards. any ideas?
Boost Monkey is offline   Reply With Quote
Old 01-19-2006, 11:52 PM   #2
Dousan_PG
Dousan_PG's Avatar
tranny is fucked
remove and replace
Aaron
Pink GodziRa
Old 01-20-2006, 12:01 AM   #3
NemeGuero
No more nissan.
NemeGuero's Avatar
Werd..
Pull it off and check out what's up.. either way you'll be replacing something in there.
Old 01-20-2006, 12:09 AM   #4
OdessaS13
OdessaS13's Avatar
OdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the roughOdessaS13 is a jewel in the rough
Send a message via ICQ to OdessaS13
new tranny is not too expensive, you can change tranny and put new clutch in..2 birds 1 stone
1992 240sx 5 spd. - Sold / 02 Maxima Se
OdessaS13 is offline   Reply With Quote
Old 01-20-2006, 12:13 AM   #5
NemeGuero
No more nissan.
NemeGuero's Avatar
Refurbished s14s go for 450 from parts suppliers.
Old 01-20-2006, 12:18 AM   #6
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
does it make a loud pop sound almost? If so, most people have that problem on our cars its nothing. But grinding, i'm not sure.
sblack13 is offline   Reply With Quote
Old 01-20-2006, 01:13 AM   #7
OdessaS13
OdessaS13's Avatar
tranny is fuckedremove and replace
/\ the question is answered, get one from R240NA and call it a day
Old 01-20-2006, 04:10 AM   #8
TAMTANIUM
TAMTANIUM's Avatar
TAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the rough
I have the same problem also. I guess it's time to get a new tranny and clutch install.
TAMTANIUM is offline   Reply With Quote
Old 01-20-2006, 01:03 PM   #9
Boost Monkey
fuck....
guess im gonna shop for a new tranny, maybe even a new engine (got 220k on the ticker). gonna do a compression test to determine that though. thanks for the help
Old 01-20-2006, 06:20 PM   #10
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
Sure its not the rear calipers? Mine started doing it not that long ago. I replaced the rear pads but then both calipers started doing it so I might just replace the calipers and rotors for the hell of it to see it the noise stops.
SnakeKack is offline   Reply With Quote
Old 01-20-2006, 08:40 PM   #11
Dousan_PG
Dousan_PG's Avatar
ooh yeah i forgot.hahahah good point i had that once
pads were worn incorrectly. replaced and it was quiet
if its still nto that, trannies fucked
Aaron
Pink GodziRa
Old 01-20-2006, 10:49 PM   #12
Boost Monkey
cant be rear pads cuz the sound comes from the tranny area.
