Old 02-23-2006, 11:58 PM   #1
blazn240sx
blazn240sx's Avatar
blazn240sx is an unknown quantity at this point
Help Ka24de over heating
hi my friend just bought a car recently found out no thermostat ok so we added one right the car now overheats we try everything to fix it but no response ok what we change are, waterpump, radiator and cap, clutch fan, and upper and lower hoses the coolant 3 times bleed it about 5 times and now thinkin about changing the heater core because at some time when it overheat and we turn on the heater it doesnt work but when it at normal driving tempature it works so im stumped i dont know what else to change please give ideas and it only happens when we are driving it on the street through stop and go but on the freeway it fine
blazn240sx is offline   Reply With Quote
Old 02-24-2006, 12:17 AM   #2
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
http://club240.com/forums/showthread.php?threadid=8769
Search noob. And type in a proper way that I can actually read wtf you are trying to communicate.
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 02-24-2006, 07:10 AM   #3
boosteds13
boosteds13's Avatar
boosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really niceboosteds13 is just really nice
WTF kind of response was that? You linked him to an entirely different forum. The "search noob" flame only works if you link him to a thread local to the board you are on.
"A CA? WTF is that? You shoulda got an SR yo."
View my vBPicGallery!
boosteds13 is offline   Reply With Quote
Old 02-24-2006, 08:04 AM   #4
aznpoopy
aznpoopy's Avatar
you can try bypassing the heater core to see if thats causing blockage.
my friend is having the same issue with his cavvy. changed the radiator, e-fan, thermostat, waterpump... basically everything except the heater core. final diagnosis... blown headgasket. it was a very tiny leak. it didn't overheat at idle. but once you drove it at any appreciable speed, it overheated.
Old 02-24-2006, 08:30 AM   #5
pr240sx
pr240sx is an unknown quantity at this point
Air trapped in the system.
The heater is off the loop when the AC is in Cold position
At least on the S13
pr240sx is offline   Reply With Quote
Old 02-24-2006, 10:37 AM   #6
blazn240sx
blazn240sx's Avatar
thank to all the people responding will check headgasket
Old 02-24-2006, 10:42 AM   #7
[HK]240sx
[HK]240sx's Avatar
[HK]240sx is an unknown quantity at this point
Send a message via AIM to [HK]240sx
Junkhouse.us/blog | RWB | Touge Factory
[HK]240sx is offline   Reply With Quote
Old 02-24-2006, 10:43 AM   #8
blazn240sx
blazn240sx's Avatar
think im going to do a leakdown test
Old 02-24-2006, 05:04 PM   #9
neverlift
neverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymore
blocked head, did you use rtv silicone on yor water pump?
derp derp
neverlift is offline   Reply With Quote
Old 02-25-2006, 09:35 PM   #10
blazn240sx
blazn240sx's Avatar
yes i did use rtv silicon and a gasket also the heater now dont work it only blow cold air now
Old 02-25-2006, 10:02 PM   #11
TAMTANIUM
TAMTANIUM's Avatar
TAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the rough
make sure you add more water than coolant...try that. Just keep adding water.
TAMTANIUM is offline   Reply With Quote
Old 02-25-2006, 10:07 PM   #12
Agamemnon
Agamemnon's Avatar
Is it possible that you may have a coolant leak somewhere and that it has let some air in everytime you start the car?
I have the same prob. My heater doesnt work until about ten minutes into driving and I have small leak somewhere under the intake mani.
Old 02-25-2006, 10:23 PM   #13
Irukandji
it's funny when newbs call people newbs
sorry we don't search the entire interweb.
Old 02-25-2006, 10:23 PM   #14
g6civcx
g6civcx's Avatar
1) Did you install the thermostat with the jiggle valve in the proper orientation (pointed up)? If not, check it. Check that the thermostat operates properly and opens up for coolant flow when warm.
2) Did you pressure test the cooling system to determine if it's hold proper pressure and if there are any leaks? If not, do it. It should only cost you a few bucks. Any reputable shop will have the proper testing tool and know the proper procedures. Fix the problems, if any.
3) Did you perform a coolant flush? If not, do it. Not just a drain and refill since it will only clear out fluid in the radiator, but a complete flush and transfusion with new coolant.
4) Is your cooling fan working properly? Do you have the factory fan shroud? This will help airflow. Check to make sure that the shroud is not broken. Also check to see that the fan mechanism operates correctly.
