Old 02-25-2006, 10:48 PM   #1
NemeGuero
No more nissan.
NemeGuero's Avatar
Oil return line.
Is the oil return line pressurized?
I have just a silicon hose going gravity fed into the tap on my oil pan but it seems to be leaking from the top clamp and bottom clamp. I tightened them up a little but I'm wondering if its a better idea to invest in a steel line with a screw type fitting or something.
What do you guys think?
Old 02-25-2006, 10:51 PM   #2
CHARLIE2020
CHARLIE2020 is an unknown quantity at this point
Send a message via AIM to CHARLIE2020 Send a message via Yahoo to CHARLIE2020
Nope it's not pressurized its gravity drained.
CHARLIE2020 is offline   Reply With Quote
Old 02-26-2006, 09:00 AM   #3
g6civcx
g6civcx's Avatar
The return line is not pressurised. I'm going through the same issue so I will keep you updated. Right now the best I can find is this:
http://www.customsteel.com/sr20/html..._fittings.html
He'll give you the fitting with a straight or 45* -6 fitting. Then it's up to you to figure out how to get it into the block.
I'm working with Harp @ Taka Motorsports right now to figure this out. I'll keep you posted on what I come up.
Old 02-26-2006, 01:06 PM   #4
NemeGuero
No more nissan.
NemeGuero's Avatar
Thanks for the info. I just threw on another clamp so hopefully it stops leaking.
And thanks for the link, but I don't have an SR.
I'll give them a call anyways and see if they'll have the fittings for me.
-Evan
Old 02-26-2006, 02:17 PM   #5
g6civcx
g6civcx's Avatar
-Evan
The fitting is meant for a T25/8. They also carry GT series fittings. Give Pat a shout and he'll set one up for you.
Then you can figure out how to get it back to the block. Maybe the best way for you is to run it straight to the oilpan. How are you running it now?
Old 02-26-2006, 03:42 PM   #6
NemeGuero
No more nissan.
NemeGuero's Avatar
Its going to the pan now. I have a 90degree hose pipe tapped in the pan for the return feed.
I'm using a t3/t4... I haven't had a chance to call yet, but i'll get around to it.
Old 02-26-2006, 04:11 PM   #7
g6civcx
g6civcx's Avatar
He's getting ready to do a show right now so if you can't catch him, email him.
