Old 02-26-2006, 07:56 PM   #1
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
Originally Posted by broken240sx
I meant that you wont get accurate compression numbers when testing the engine unless it is running.....
Again you seem to have missed the point. How in the hell are you going to test compression with the engine running? It doesnt work like that.
As to the original poster, I would at least lift the valve cover and make sure that the CAS is installed correctly. It isnt entirely unheard of to recieve an engine with another CAS that was just shoved in and is totally out of time. Shouldn't take too long and you can then rule that out as problem if its correct.
Big Bronze Rim is offline   Reply With Quote
