Old 03-12-2006, 10:34 PM   #3
ledzeppelin240
ledzeppelin240's Avatar
ledzeppelin240 is a well-known jackass
If I remember right they are closed untill vacuum is applied. All you need is some anaerobic sealer and a small oil gallery plug to plug the hole left when the actuator is removed. You take off the screws holding the plates onto the rod and a screw in the center then pull the rod out.
Anyway, no drug, not even alcohol, causes the fundamental ills of society. If we're looking for the source of our troubles, we shouldn't test people for drugs, we should test them for stupidity, ignorance, greed and love of power.
Looking for: JDM S13 OEM Sideskirts
ledzeppelin240 is offline   Reply With Quote
