Old 03-20-2006, 06:35 PM   #1
AntiVtec
AntiVtec is an unknown quantity at this point
Originally Posted by smithers584
did you go from side mount to front mount? did the location of your MAFS change? i know this sounds obvious, but did you check for boost leaks on the intercooler couplings? pinch off the blow by hose that runs to your pcv valve, if your engine speed rises then you have a leak, if everything is ok then it will idle rough when you pinch it off and then go back to normal after releasing.
Yeah i went to front mount, no the maf local didnt change. No leaks detected after alot of searching. Ill try pinching the hose, which is the pcv hose? Thanks alot for the help ill keep you posted.
AntiVtec is offline   Reply With Quote
