Old 03-25-2006, 03:21 PM   #1
smithers584
smithers584 is an unknown quantity at this point
02 sensor question
s13 blacktop. ok guys, need your experience. does the 02 sensor only come into play at idle or could it cause my car to run like shit and die if it were bad. seriously, ive checked everything else including sensors and wires, leaks and fuel pressure, and this is the only thing i think i have found bad. the FSM gives ohmage for a heated o2 sensor, but mine is not heated. its says to shoot 3-1000 ohms, yes thats right, on pins a and c. mine shoot completely open. need help seriously, any ideas or suggestion are also appreciated. btw, no other codes expect 55 from ecu.
smithers584 is offline   Reply With Quote
Old 03-25-2006, 03:46 PM   #2
smithers584
also, just checked my knock sensor, .53 mega ohms to ground. FSM just says to make sure you have continuity. anyone?
Old 03-25-2006, 04:16 PM   #3
g6civcx
g6civcx's Avatar
Why are you not running a heated O2 sensor on a turbo engine?
Old 03-25-2006, 05:17 PM   #4
smithers584
well how do i tell if its a heated 02 sensor. this could be wrong, but i was told that s13 blacktops do not have heated 02 sensors. to tell you the truth, i dont know anything about the difference or why you need a heated one. maybe it is heated, how do i tell? its got three wires going into it but thats about all i know.
Old 03-25-2006, 05:20 PM   #5
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
heated would have 3 wires.
OEM nissan fat (blacktop) o2: 22690-50F03
OEM nissan skinny (redtop) o2: 22690-50F00
driftingisgay.com
nrg is offline   Reply With Quote
Old 03-25-2006, 05:26 PM   #6
Blues13
Blues13 is an unknown quantity at this point
Why would it matter that his engine is turbo?
Blues13 is offline   Reply With Quote
Old 03-25-2006, 05:31 PM   #7
smithers584
ok well if the 3 wires means it is heated, then thats what i have. its shooting open, so i guess i need to change it per FSM. thanks for the help, ill update on the fix. can anyone explain the reason it needs to be heated, like i said, i dont anything about that.
Old 03-25-2006, 05:40 PM   #8
g6civcx
g6civcx's Avatar
An unheated sensor has to sit close to the exhaust port to be brought up to temperature. When you heat up the sensor artificially, it doesn't have to sit that close to the exhaust port, and you can move it further downstream. This helps protect the sensor from heat cycles that an unheated sensor sees.
Another benefit is that heated sensors come up to temperature more quickly. An unheated sensor has to wait for the engine to come up to temperature for the exhaust to heat up the sensor. So the heated sensor kicks in sooner.
The turbo produces so much heat that you want to move the sensor further downstream and heat it artificially. Your S13 blacktop has a heated sensor. You can tell by the 3 wires. The 2 outside wires are for the heating element, and the middle wire is sensor signal.
Old 03-25-2006, 06:07 PM   #9
smithers584
awesome info, thanks man. ill try and get the sensor tomorrow and post with any changes.
