Old 03-27-2006, 04:18 AM   #10
g6civcx
g6civcx's Avatar
Originally Posted by mjjstang
i was told by someone on this fourum to put the wg line after the tb, it helps with spool while shifting or somethin
Consider the source. You can put it behind the throtte plate, but compressor pressure won't be as accurate if you put it before the throttle plate. It may help spool because the throttle plate is closed and compressor pressure is not being diverted to the wastegate, but there may be other consequences you need to consider.
